Ignition module?
Old Jul 20, 2008 | 03:41 PM
HighdefJoe's Avatar
HighdefJoe
Ignition module?
One question about the engine swap I'm doing....
My 86 2wd 300 has the same module as the 93 mustang I'm pulling the 331 from. Will the module setup just swap over from the 6 to the 8 with no problems, other than extending the wires?
Old Jul 20, 2008 | 07:54 PM
Franklin2's Avatar
Franklin2
It should. If you want to make sure, look both vehicles up at www.partsamerica.com and see if both replacment modules have the same part number.
Old Jul 20, 2008 | 08:00 PM
HighdefJoe's Avatar
HighdefJoe
They do. I work at a parts store and I've checked into it. PN's are the same but I wanted to make sure that it was OK to switch from a 6 to a V8. Thanks!
