Directional Switch Auto-Cancel
Old Jul 20, 2008 | 03:05 PM
SpringerPop's Avatar
SpringerPop
When I go to turn right I now have to physically hold the turn-signal lever up, as it won't stay there any more. Left works just as advertised.
Has anyone been inside their steering wheel recently to address this issue, and if so, what's the solution? Is there some kind of "hook" that's worn or broken off? Is there a pin that needs to be tweaked a little?
Anybody?
Pop
Old Jul 20, 2008 | 05:22 PM
megawatt00's Avatar
megawatt00
It is part of the multi function switch. i have found this so far:
Multifunction Switch
Removal & Installation
To Remove:
Remove ignition switch lock cylinder.
Twist the tilt wheel handle and shaft to remove.
Remove upper and lower steering column shrouds.
Remove screws, disconnect electrical connectors and remove multifunction switch.
To Install:
Install multifunction switch and screws.
Connect electrical connectors.
Install upper and lower steering column shrouds.
Install tilt wheel handle.
Install ignition switch lock cylinder
Old Jul 20, 2008 | 05:35 PM
SpringerPop
So it looks like a multi-function switch is in my future? OK, I can handle that.
Thanks, Jim for the write-up! (Yes, I gotta spread 'em around still......)
Pop
Old Jul 20, 2008 | 05:43 PM
megawatt00's Avatar
megawatt00
Do you have the link to the workshop manual? It has the pics in it.
Old Jul 20, 2008 | 05:51 PM
SpringerPop
Wanna refresh my memory?
Thanks,
Pop
Old Jul 20, 2008 | 05:55 PM
megawatt00's Avatar
megawatt00
Here you go post #15 has 1996 to 2008 I use this all the time
https://www.ford-trucks.com/forums/7...nual-link.html
Old Jul 20, 2008 | 06:20 PM
SpringerPop
Found it. Looks kinda easy. Maybe an hour at the most.
Thanks again, Jim!
Pop
Old Jul 20, 2008 | 06:22 PM
megawatt00's Avatar
megawatt00
Your Welcome Pop!
Old Jul 20, 2008 | 06:44 PM
SpringerPop
OK, where do you all recommend I get one?
Pop
Old Jul 20, 2008 | 07:42 PM
megawatt00's Avatar
megawatt00
That may be a dealer item. Check with the FTE parts guy ED.
PM sent
Edit:
I found it at Auto Zone
http://www.autozone.com/R,919321/veh...ductDetail.htm
Old Jul 21, 2008 | 11:06 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
I dont think the autozone one is the right part number.
Y85Z13K359CA check my site for price. I have one in stock.
Ed
Old Jul 21, 2008 | 11:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FTE/PARTS-GUY
I dont think the autozone one is the right part number.Ed
It isn't right. They list it as # SW2857...There is no such number.
I chimed in because Marv asked me this question yesterday calling it a multi function switch.
I didn't realize what he wanted was the turn signal switch (13K359)...I thought what he wanted was some sort of a 14A089.
Sorry Marv....if I had known, I would have given you the part number and Ed's price.
Old Jul 21, 2008 | 11:23 AM
mueckster's Avatar
mueckster
I bought the OEM one, the parts house ones weren't really cheaper. I try to stay with the OEM on many of the replacement parts.
Old Jul 24, 2008 | 12:55 AM
BobbyDiesel71's Avatar
BobbyDiesel71
I had the same part go bad
make SURE you get the right part # from FOMOCO
I had to return the one for a 99-01 and get the 02-04
I will look for the p/n
bob
Old Jul 24, 2008 | 07:37 AM
mueckster's Avatar
mueckster
bob
I had to give them the VIN to be sure I got the right one. The application info was not enough. They didn't have the correct one in stock at the time.
