1994 flareside 5.8 electrical
When I turned the key to start I heard a pop and all power died.Had 3.5 volts at the battery..Installed a new battery and the same thing happened,this is why I am here..Do you think it is the starter?
A pop? That doesn't sound right. Was the battery that you replaced bulging at the sides? Have the battery cables ever been replaced?
Last question, i almost feel weird for asking. Are you sure you put the red to (+), and the black to (-)?
Happens only when you turn the key to "start"?
Sounds like you have a dead short to ground, check the positive cable to the relay and from the relay down to the starter.
Melted to the exhaust or pinched some place?
The starter may have a dead short in it, check it if the cables are clear.
