Power window problem
Old Dec 11, 2002 | 10:22 AM
fishcamp's Avatar
fishcamp
[updated:LAST EDITED ON 11-Dec-02 AT 11:24 AM (EST)]Can the power window motors be rebuilt? My '95 F-150 driver's window began to only work from time to time and now it does not work at all. There is power to the switch and the motor gets hot but does not move at all. Heard they are expensive to replace.
Old Dec 11, 2002 | 10:36 PM
steve83's Avatar
steve83
The motors aren't serviceable - the brushes are assembled to the rear bearing plate, and can't be replaced. Remans are about $80.
Old Dec 12, 2002 | 03:01 PM
troposcatter's Avatar
troposcatter
Try here, sales@windowmotor.com I purchased rebuilt motors for my wifes truck at Checker but I still have the old motors and the people at windowmoter sell the gear kits, Take your motor off the regulator and make sure the gearbox isn,t jammed I had one of those, the ones I took off had deteriorated cushions in the gearbox.
Old Dec 28, 2002 | 06:51 PM
kenpoore's Avatar
kenpoore
Does anyone know where you can buy those "cushions"? I need a dozen of them. Has anyone found an alternative to using the factory cushions? Thanks for the help!
Old Dec 28, 2002 | 07:58 PM
Mil1ion's Avatar
Mil1ion
Faucet washers at plumbing stores.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 29, 2002 | 12:29 AM
steve83's Avatar
steve83
Sections of coil spring, rubber fuel line, copper line, or hard plastic bushings work, too.
Old Dec 29, 2002 | 12:55 PM
mantta's Avatar
mantta
I have done quite a few of them, and, what I have used is three pieces of teflon rod cut just under a half inch long. They fit right in there where the cushioners were. I have also taken the motors apart and put brushes in them. I get a pack of carbon appliance motor brushes and file or grind them to size, they have always worked. At the same time clean up the comutator with fine emery paper.
Old Dec 29, 2002 | 09:22 PM
Mil1ion's Avatar
Mil1ion
