Very simple question about solenoids
Old Dec 30, 2002 | 02:05 PM
Wstrombe's Avatar
Wstrombe
My van came with a number of solenoids which were used to power extra lighting, a compressor, lots of other things. They all look the same, just like almost every solenoid you have ever seen, except that some have a small "x"- italicized-- on the LEFT side mounting tab, and others on the RIGHT side.
Am I right in my suspicion that the side with the "x" is the side which battery current should run to? Or do they mean something else, or maybe nothing at all?
Thanks for any help.
Old Dec 30, 2002 | 07:20 PM
Mike W's Avatar
Mike W
Except in the case of the Ford solinoid that has the two small terminals, the connection to the battery should not matter. If the I terminal was not used, even the Ford type could be reversed.
Old Dec 30, 2002 | 10:17 PM
steve83's Avatar
steve83
Those are "relays", not "solenoids". A solenoid is used to push or pull - when it's permanently connected to an electric switch, it's called a relay.
Old Dec 30, 2002 | 10:19 PM
steve83's Avatar
steve83
Toakley123
16
Oct 15, 2016 06:53 AM
Kasman61
1997 - 2003 F150
Nov 16, 2014 02:17 PM
cityjack
Feb 9, 2014 08:49 PM
army89
May 16, 2011 08:23 PM
lopitt85
17
Sep 23, 2009 11:25 PM
