Finally gauges in july, part too....
Old 07-19-2008, 03:21 PM
big poppa's Avatar
big poppa
big poppa is offline
Got the red and yellow leeds hooked up to the thermocoupler, where does the other end go to, the gauge it self or do i tap in to the red and yellow junction box under the dash? THANKS One more pic!!!
Last edited by big poppa; 07-19-2008 at 03:22 PM. Reason: hOLD ON, GOT ONE MOE PIC!!
Old 07-19-2008, 03:26 PM
big poppa's Avatar
big poppa
This is the wire coming from the thermocoupler, where does the other end go, to the gauge it self or do i tap into that junction box yellow and red wires?. These ends have loop conections. Help fast please......
Old 07-19-2008, 03:33 PM
liftedgrocerygetter's Avatar
liftedgrocerygetter
liftedgrocerygetter is offline
I think Brandon answered in your other thread Mike. Wish I could help ya but I have no idea
Old 07-19-2008, 03:34 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
There will be two wires that comefrom the box through the firewall and down to the Thermo couple wires, and then 2 wires that go to the guage from the box
there will be two wires with ring terminals that connect to the two ring terminals on the TC, and then go through the firewall to the box.<!-- / message --><!-- sig -->
__________________
sent you a PM call me
Old 07-19-2008, 03:50 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
Here's some pics from Dieselmanors installation sheet on the web.
Using a 1/8" NPT tap, tap the hole. Apply a small amount of anti-seize lubricant to the threads of the fitting and tighten. Insert the probe with its nut and ferrule. You want the tip of the probe to be in the center of the exhaust flow. Usually this means that it will need to be inserted 1 inch past the threads that you tapped. Tighten the nut no more than 1 full turn past finger tight. Connect the thermocouple wires to the lead wire using the supplied nuts and heat protective sleeves. You will be connecting the thermocouple to the end of the lead wire that has a long red lead and a shorter yellow lead.
2) Thermocouple Connection:
Connect the red/white color (negative -) wire to the red thermocouple/leadwire.
Connect the yellow color (positive +) wire to the yellow thermocouple/leadwire.
For easy and effective wire connections, the above wires are provided with a set of screws and nuts.
Leadwire is available in lengths of 6’, 10’, 14’, etc.
IMPORTANT INSTALLATION NOTICE FOR LEADWIRE ONLY
In order to connect the wires from the signal amplifier box to the top of the leadwire, it will be necessary to:
1. Bend the red wire up so as to make it even with the yellow wire.
2. Disassemble the nuts and screws.
3. Slide the fiberglass sleeves over the red and yellow wires.
4. Connect the leadwire and reassemble and tighten the nuts and screws.
5. Pull the fiberglass sleeves over the connections.
click the pdf link below to see the wiring diagram
link to more pics & info.
http://www.dieselmanor.com/docs/isspro/ISSPRO-IS026.pdf
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old 07-19-2008, 04:18 PM
white Buffalo
here's the wiring diagram:
Connect the ring type ends together with the supplied screws & nuts.
Old 07-19-2008, 04:38 PM
big poppa's Avatar
big poppa
Thanks everybody, with all them wires under there, found what i was looking for, WHHEEEHHH. Thanks again for the quick response and the panic attack is finally over,lol.
Old 07-19-2008, 08:09 PM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Ok, what is the outcome. Darn man let us know.
Old 07-19-2008, 08:11 PM
white Buffalo
Rick,
He must be out driving & having fun with the new toys.....
Old 07-19-2008, 08:43 PM
miller_feed
Originally Posted by white Buffalo
Rick,
LOL, Yeah, I think he is getting lower mpg's right now. Good for him.
Old 07-19-2008, 08:51 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
I think Mike may have started celebrating without us.
Glad you guys were here to help him out.
Old 07-19-2008, 09:49 PM
bdrummonds's Avatar
bdrummonds
When I talked to him on the phone today Mike said he had to go in to work at 10 tonight, so hes at work now.
Old 07-19-2008, 09:59 PM
zx250's Avatar
zx250
zx250 is offline
Well now, that sucks. Thanks for helping him out Brandon.
Old 07-20-2008, 12:29 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Interesting. My gauges do not use a circuit box. Wired straight to the gauge. Different brand so there ya go.
Old 07-20-2008, 07:45 AM
big poppa's Avatar
big poppa
Just got home and i'll give the run down, had some time Sat morning before the family came over for a swim and eats to at least get the pillar and gauges wired and set up because i knew i wasn't going to get it all done. Everything is done except the for powering them up and the pyro tap. Boost is done also. Here,s where i got fustrated, after getting everything in and set up i look to see where the other end of the pyro ring terminal leads hook into. First thing i thought they went to the junction box, i look, no not there. I said O-S, does it go to the gauge after installing the pillar already. (following all the directions to a tee) After freakin out i turned to you guys for some help and you responded fast. Brandon PM,ed me and told me to call him and i did, while talking to him and running down the problem i pulled the carpet back under the dash and there was the ring leads that came off the box i needed to connect to the pyro wire. Man o man, brain fart, big time. Does it happen, yes but when you got a great bunch of people helping out like this it make,s it all worth while, thanks again. I'll report back in a little bit after i do the tap pre-turbo and powering it up.
Quick Reply: Finally gauges in july, part too....
