Radiator einforcement panel.
Old Jul 19, 2008 | 01:36 PM
Fordzilla80's Avatar
Fordzilla80
In the future i am planning to swap to a 302 from my 300.Since the truck has a 6 it has a smaller radiator than a 302 would.I was wondering.When i swap to the 302,and add a bigger radiator,will i need to swap reinforcement panels too since the hole is only cut for a small radiator?
Old Jul 19, 2008 | 03:02 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The 300 had three types of cooling systems.
Standard (Small radiator)
Extra Cool (small Radiator)
Super Cool (large Radiator).
Super cool radiator was standard with A/C on the 300.
The 300 and 302 radiator are different. You will have to get the radiator that matches your engine.
As for the Radiator support. I recommend changing it out when you install the large 302 radiator.
Even though the 302 larger radiator will fit and bolt up to the support you currently have, the hole in the front to let air to the radiator fins is smaller to accomodate the small radiator.
I recommend getting the radiator support for the larger radiator, that has a larger hole in the front. This way the maximum air flow can reach the radiator.
hope this helps.
Old Jul 19, 2008 | 06:12 PM
Fordzilla80
hope this helps.
Yea that's what i thought.Someone had told me it wouldn't make a difference but i wanted to get a better and more educated opinion.
Old Jul 19, 2008 | 07:31 PM
ri_truck_guy's Avatar
ri_truck_guy
I installed a factory A/C setup in a non-A/C 300 truck several years back. It took about three minutes to enlarge the radiator opening using a sawzall. It's all thin sheet metal...the bracing is around the larger opening. If you look at your exisitng support closely you'll see it's essentially pre-marked for the cut. I wouldn't consider changing the core support for even a second.
Old Jul 19, 2008 | 08:38 PM
81-F-150-Explorer
What did you do about the "lip" that is on the sides to keep the air from going around the radiator? Did you re-weld it in it's new position, or leave it off?
14 bolts and screws hold the support in. It's not a hard swap.
It would even make swapping engines easier. IMO.
Old Jul 19, 2008 | 09:01 PM
ri_truck_guy
It would make swapping the engines easier....
I did my swap in 2002, and I don't specifically recall reworking that lip, although it would be pretty simple just to tack it on in the new location. It's pretty small to begin with. In my case, it was either there already, or I didn't need it. The truck had no temperature issues with the new setup in it, but that was still with the 300. The 302 might run a little hotter.
