Timing problem on a 400
Old Jul 20, 2008 | 11:46 AM
Deluxetruck's Avatar
Deluxetruck
Vacuum advance is only there to increase fuel economy under part throttle cruising. Unhook it, plug the vacuum line from the carb and drive it. If that doesn't fix the problem, we'll know it's not the vacuum advance.
-Jared
Old Jul 20, 2008 | 12:19 PM
80broncoman's Avatar
80broncoman
Is the engine and ignition system in a stock configureation? Use the stock timing specs if so.
If not I'd time by ear myself.
Backfiring out the exh I'd think the timing is way to retarded if it was the ignition.
Old Jul 20, 2008 | 06:38 PM
0351mike's Avatar
0351mike
The truck has stock ignition, as far as the motor- I have no way of knowing- looks and sounds like a mild cam- towing I expect. I have been messing with the timing all day- I was always taught advance it until it pings under load and back it up a little. It seems to run better advanced past the the stock 12 BTDC. I was also taught throw the book out once you put the an aftermarket cam it- is this correct- should I be timing by ear? Should I push advance it as far as I can? Also can I disconnect the vacuum advance and plug it? If that is so why do they still have advance on performance motors- I have a 351c in a 72 Mach1 that has mechanical advance? I alway thought it was there to keep the timing right as the RPMs increased?
Old Jul 20, 2008 | 08:27 PM
Deluxetruck
Mechanical advance and vacuum advance are two different animals. The quick version looks like this. Initial timing or base timing is what you set with a timing light. From there, mechanical advance adds timing advance as rpm rises, at least until the system of weights and springs inside the distributor reaches its full advance. All of that is adjustable depending on your combo. Vacuum advance adds still more advance under part throttle cruising in an effort to increase mileage. Many high performance dizzy's do not have vacuum advance, but they still need mechanical advance to run optimally, unless they are electronic or are locked out, but that is something else entirely. Unhook the vacuum advance, you still have mechanical advance, go drive it and let's eliminate one thing at a time.
-Jared
Old Jul 21, 2008 | 05:51 AM
0351mike's Avatar
0351mike
Thanks Jared- I will give it a try this morning and let you know how I make out.
Old Jul 21, 2008 | 05:06 PM
80broncoman
Originally Posted by 0351mike
.....I was always taught advance it until it pings under load and back it up a little. It seems to run better advanced past the the stock 12 BTDC. I was also taught throw the book out once you put the an aftermarket cam it- is this correct- should I be timing by ear? Should I push advance it as far as I can? Also can I disconnect the vacuum advance and plug it? If that is so why do they still have advance on performance motors- I have a 351c in a 72 Mach1 that has mechanical advance? I alway thought it was there to keep the timing right as the RPMs increased?
Yes I'd forget about the stock timing specs on a engine that has a cam, or different compression. Crank it up till it runs good. Be warned though if you sometimes use it as a working truck,(hauling and towing) you will probibly need to strike a compramise on the timing.
(What would be ideal would be to have a Timing adjustment on the dash like the MSD makes).
I have a 77 F150 with a 351m or a 400 (not sure which) that is not stock and I use it as a work truck I left the vac advance hook to the ported vac so when the load is light I get plenty of timing and as much MPG as I can get. But at near WOT and lower vacume and RPM (high load) it will not ping.
Old Jul 22, 2008 | 06:34 AM
0351mike's Avatar
0351mike
OK- disconnected and plugged the vac advance- and drove the truck for 20 miles- back roads and highway. It did backfire for a few seconds at 60 mph on the highway, but after that I could not get it to miss again. No miss or backfire in third as before and seems to run all around better- So does that tell me that I have a problem with the actual vac advance on the distributor?
Old Jul 22, 2008 | 03:50 PM
80broncoman
Look at the wires that go from the mag pick up to the module. Between the mag pick up and where the wire are held down just before they go though the dits body. some times the wires can break with out the insulation looking bad at all. Friend of mine had the same problem years ago on a 302. Every time the mag pickup moves because the vac advance pulls it the wire bend. The wires can only bend so many times. If you had a tach on it I bet when it would be missing and backfireing the tach will jump all over the place.
Old Jul 23, 2008 | 08:17 AM
0351mike's Avatar
0351mike
Thanks- I will take a look
Old Jul 23, 2008 | 09:20 AM
f250hiboy's Avatar
f250hiboy
Sounds like all great advice..the vacuum advance should be plug in on the front of your carb.. Not the tree behind the carb...but nobody talking about fuel....How much fuel pressure are you getting....what size carb?
TURBOSCHILZ
30
Mar 25, 2014 10:42 PM
scottyace
1978 - 1996 Big Bronco
Sep 30, 2012 03:46 PM
77F250CUSTEXP
Jul 8, 2011 11:47 AM
stevef100s
Apr 8, 2004 10:09 PM
Sportcustom69
Dec 5, 2002 10:45 AM
