99 psd sometimes wont start
Old Jul 18, 2008 | 06:01 PM
engine1's Avatar
engine1
I changed the oil in the morning one day and pulled the truck out of the garage and parked it. I went back out later that day and try to start it and the thing wouldnt fire over, for about 3 or 4 tries. It finally fire and was spitting and sputtering, it finally smoothed out alittle by the time I shut it off.
The next day it did the same thing and when I got it started it ran terrible. In fact I didnt think I was going to make it to my destination. When I arrived where I was going it smoothed out and ran fine, and has since ran fine but it does the starting thing every once in a while. The ses light does come on when i accelerate and I had the cps changed . Any Ideasdu
Old Jul 18, 2008 | 06:03 PM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE....did you fill the oil filter before you put it on?? what oil did you use???
Old Jul 18, 2008 | 06:16 PM
mueckster's Avatar
mueckster
I would read the codes and see if they are related to something that would cause this.
Old Jul 18, 2008 | 06:34 PM
engine1's Avatar
engine1
I filled the oil filter with rotella. I also had a guy get the codes for me and I'm not a mechanic but he said it had something to do with exhaust pressure and fuel pressure.
Old Jul 18, 2008 | 07:08 PM
F350-6's Avatar
F350-6
Welcome to FTE. Is there any chance of finding out the exact codes?
What weight of Rotella did you use, and how much oil did you put in? When you pulled the truck out of the garage after the oil change, did you let it idle long enough immediately after start up to build up the oil pressure (have the dummy gauge move) before you backed the truck out? Did you happen to change the fuel filter at the same time?
Old Jul 18, 2008 | 07:35 PM
zx250's Avatar
zx250
Of the next Riffraff East
This may seem simple, but have you rechecked your oil level since the change? These things are very sensitive to oil level.
Old Jul 18, 2008 | 09:54 PM
engine1's Avatar
engine1
I checked and rechecked oil. I just changed fuel filter before oil change, i have another one i guess I could try that. I cleaned air filter too.
Old Jul 18, 2008 | 09:57 PM
F350-6's Avatar
F350-6
When you changed the fuel filter did you drain the fuel bowl? Did you cycle the key to purge the air out of the filter bowl? If you get air in the fuel rails it will cause your engine to run rough.
Old Jul 19, 2008 | 09:05 AM
engine1's Avatar
engine1
No i didnt do it that way. It ran fine after i changed the fuel filter. It runs fine now but every once in a while it wont fire over and the ses light comes on when I give the gas to her
Old Jul 19, 2008 | 10:31 AM
mueckster's Avatar
mueckster
Find out those codes and report back. They might be able to point you in the right direction as to the problem.
