Overhead console went out.
Old Jul 17, 2008 | 11:50 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
OK, my Lie-O-meter stopped working the other day when the GF took the truck for the day. There just doesn't seem to be any readings/lights on. I swear something always happens when I lend my rig out to her! Is there a specific fuse that powers this? I imagine that the wiring is all clips, so I can't really see that coming apart? Anybody have a link to the threads about this topic or an inkling on where I should start? Thanks in advance.
Old Jul 18, 2008 | 07:11 AM
zx250's Avatar
zx250
Of the next Riffraff East
Here you go. Read it all, Post #4 is from Miescha, look in his gallery for detailed pictures.
https://www.ford-trucks.com/forums/4...-gone-out.html
Old Jul 18, 2008 | 07:12 AM
F350-6's Avatar
F350-6
Here's a link for you https://www.ford-trucks.com/forums/4...ml#post3230238
But I would check the fuses first since that's much easier.
Edit: Never mind. Barry's got the same link.
Old Jul 18, 2008 | 07:58 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Ryan, also check the dimmer wheel. Someone had that problem before and the dimmer was in the off position. Just talking here.
Old Jul 18, 2008 | 12:24 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Barry, Chris, Rick. Thanks for the replies. Rick I checked all wheel already, no luck. Anyways thanks for the links fellas. That is a great write up in that post, and should keep me busy this weekend, with the oil change, and the cleaning....
Old Jul 18, 2008 | 12:31 PM
zx250's Avatar
zx250
It works, I done mine twice and two others. The only reason I did mine twice was I thought superglue would work as well as solder...NOT. It appears that heat will cause superglue to give way. Go ahead and use solder. Be careful when removing the console as the resistor may be completely loose and fall out. They are very small and easily lost. A solder pen is a must, a good eye is a must. The area you are working with is very small. Easy enough to do, just a little tedious for me.
Old Jul 18, 2008 | 12:33 PM
HighOctane's Avatar
HighOctane
PMS: an obsession
Thank you for the insight. Gives me the confidence that this will go pretty smoothly! I'll give er a shot and let you fellas know.
Old Jul 18, 2008 | 12:36 PM
zx250's Avatar
zx250
I have no doubt you can do it, the instructions were clear enough for me to follow. The pictures he has will prove your best tool. Good luck and do let us know.
