Sponsored by: Auxito
ABS will not shut off?
Old Jul 17, 2008 | 06:09 PM
cghstrojan08's Avatar
cghstrojan08
I have a 2000 F-150 with only 77,000 miles on it. When I was on a camping trip the other day, I heard a motor running when the truck was off. It was something to do with the ABS so I pulled the fuse to not run my battery down. Do you guys know what the problem could be or where to start. I first noticed it when the ABS light came on in the dash before I drove it for about 10 miles then heard the motor when I turned it off. I don't know where to start. I have had the problem though where there was metal flakes on the rear ABS sensor and it turned the light on in the dash.
Old Jul 17, 2008 | 09:42 PM
AzBlueWolf's Avatar
AzBlueWolf
sounds like an internal short to power, unless you can find something in the harness near the abs unit.
Mark
Old Jul 17, 2008 | 10:29 PM
Club Wagon's Avatar
Club Wagon
FORD's 4WABS has onboard self diagnosis & uses a special scan tool to read Fault Codes. That is a good place to start.
