hey i just joined this site this is my first post. i am trying to replace my front rotors on my '97 F-150. if you have any tips on how to do this please reply.
To get the most out of the site you will want to use our tech forums. Click on the Forums tab at the upper left and checkout the boards. I recommend this board for your '97: 1997 - 2003 F150 - Ford Truck Enthusiasts Forums I assume your rotors are stuck? This is not an uncommon problem and people have tried all sorts of things to get them off. When all else fails, use a bigger hammer. When installing the new ones, anti-seize lub on the hub will help keep them from rusting together.
