Interchangeable 351w blocks??carborator to fuel injection?
on
There is only one 351/5.8 block and it's tranny bolt pattern has always been the same. The heads got a lot of changes over the years but those too have been unchanged in terms of intake bolt patterns from 1978 on. The only issue you will have will be with the cam, if it's a carb based RV cam it won't be compatable with the EFI system, you'll need to change it to one that is. The Crane 444232 is a good choice, but there are others as well.
1FastGambler
13
06-05-2014 08:45 AM
79broncojosh
08-24-2010 05:18 PM
rebel1803
11-16-2008 05:59 PM
jeeps
06-28-2000 02:19 PM
