vac line?
Old Jul 15, 2008 | 09:58 AM
cooploops's Avatar
cooploops
vac line?
1985 ext cab longbed f150 IL6 4wd 4 sp std
while the truck is running driving etc theres a hissing noise, when I fully depress the brake pedal it stops. brakes work fine but its driving me nuts, what is it? where is it? how do I fix it?
thanks ahead of time
Shane
Old Jul 16, 2008 | 08:51 AM
cooploops's Avatar
cooploops
anyone please?
Old Jul 16, 2008 | 09:22 AM
fmc400's Avatar
fmc400
MSEE
You're going to have to look around the engine bay for an unconnected hose. Several things connect to manifold vacuum on these trucks: PCV valve, power brake booster, AC\heater controls, air cleaner warm-air duct controls, auto trans modulator (not applicable since you have a 4 speed), vacuum reservoirs. Several things run to ported vacuum - distributor vacuum advance, evap purge and EGR. You can check for vacuum leaks by spraying a can of carb cleaner at suspected areas while the truck is idling and the idle jumps. Sometimes it helps to lean out the idle really far for this check so that the jump in idle speed is noticeable, then just tune it back when you're done. Since you said the hissing changes when you get on the brakes, I'd suspect the issue is with the brake booster or the line running to it.
Old Jul 19, 2008 | 03:29 AM
biga17133's Avatar
biga17133
Have to say i agree it the hose to your brake booster...
Old Jul 19, 2008 | 07:06 AM
timcos's Avatar
timcos
My hose leaks once in a while at the brake booster as well...I guess I am going to try and find some fix for it...could be just a dried out gasket/fitting.
DreadyDiggs
Dec 6, 2014 05:11 PM
tiopet
Oct 15, 2013 06:20 AM
vjz
Dec 14, 2012 04:42 PM
Regta
1997 - 2003 F150
Jan 1, 2007 10:10 AM
JRFX4
2004 - 2008 F150
Dec 18, 2004 09:52 AM
