glow system problems
Old Jul 14, 2008 | 10:07 PM
f350 7.3's Avatar
f350 7.3
is it normal for the two yellow wires from the starter relay to glow relay to get warm and what is the best way to remove a stuburn glow plug thanks in advance! the engine is a 91 model
Old Jul 14, 2008 | 10:30 PM
AndysFords's Avatar
AndysFords
The wire is going to get warm , and for the glow plug it is swollen, meaning it got too hot. Some people on here have some good ideas, if its just one or two I leave it there as they have a tendency to break off in the engine requiring you to pull the head off the motor.
Old Jul 14, 2008 | 11:02 PM
Dave Sponaugle's Avatar
Dave Sponaugle
f350 7.3,
Welcome to FTE and the IDI diesel forum.
Look near the dip stick for a connector where the engine harness plugs into the chassis harness.
Does the connector look like it has been hot and melted on the side with the two yellow wires?
If not you may want to pull it apart and check for any corrosion.
If it looks like it has been hot, you can try to get it apart and clean the contacts, but it may be melted together.
Which cylinder is the glow plug stuck in?
Sometimes spraying PB Blaster aroung the glow plug and letting it soak will loosen the carbon on the tip.
Old Jul 16, 2008 | 02:03 PM
f350 7.3's Avatar
f350 7.3
glow plug wire question
thanks for the reply lots of help
Old Jul 18, 2008 | 02:27 PM
magusjinx's Avatar
magusjinx
Sometimes a bit of Liquid Wrench or Miracle Oil will loosen stuborm parts ...
Old Jul 18, 2008 | 02:54 PM
LCAM-01XA's Avatar
LCAM-01XA
And so will WD-40 - that's how I pulled one of the plugs on my buddy's six-niner, soak the thing with WD-40 and slowly turn it, like you'd treat a long bolt, just turning and no pulling, after a while it came out no problem.
