rough idle , stalling when ac cycles
Old Aug 10, 2000 | 08:45 PM
billyb's Avatar
billyb
i just got ac working on 88 f150, using conversion kit for 134a. no idea how long it has not worked,since i bought truck used.
the air is good and cold, except at stop and go speeds as expected with 134a, but i am having rough idle and stalling problems .
the owners manual makes reference to shutting off the air conditioning before turning off the ignition to prevent the engine from running on because of the device that compensates for extra load of air conditioning! does anyone know how to check this "device " or where to look?
i have i-6 engine
if this is not the problem, then what to look for? bad compressor??
thanks for any advice!
Old Jan 2, 2001 | 05:19 AM
fordiesel69's Avatar
fordiesel69
The device is called and IAC (Idle Air Control) motor. The I-6 engines have a lot of problems with the idle controls. You need to get the computer scanned for any trouble codes and replace any sensors. Also try removing the throttle body and clean until all carbon deposites are gone.
Old Jan 7, 2001 | 11:34 AM
bronclover's Avatar
bronclover
midsouth
Jul 29, 2016 12:03 PM
tony montana 42
6.7L Power Stroke Diesel
19
Jun 14, 2016 09:08 PM
runstang22
2004 - 2008 F150
Aug 8, 2013 07:29 AM
resmith1
Oct 11, 2005 10:25 PM
Green Streak
Ontario Chapter
Aug 13, 2005 05:47 PM
