Spark Plug Question
Spark Plug Question
Has anyone ever paid to have their spark plugs changed at the dealer. I would just like to get an idea of the cost. I have a 04 screw with 36000 on her. I tried to take the plugs out to put anti-seize on them but they seemed really tight. Plus my extension that I have barely got up high enough to get a good amount of torque on the ratchet. I am just considering letting them deal with it, as I dont want to break one of the plugs off in the head. I have read the TSB it doesnt seem that bad, maybe I just felt like I was putting to much torque on the ratchet. Oh well, I appreciate everyones input.
Yeah, its the 5.4. The 600 wouldnt be to bad. Did they have any problems when they changed your plugs out. It does bother me because I am a do it yourselfer, and I just dont know about this one. Ive built engines, pulled trannys. You name it Ive probably done it. But when I think about this if I broke one of the plugs the cost to get it towed in, to have them mess with it then. Im just trying to weigh my options.
if you want to do it anyways, I suggest you do it at home first. Most repair shops have agreements with towing companies. If they do the work, the tow is free. Just call the dealership real quick and find out.
If the tow is free, what is there to lose? if nothing goes wrong, you pocket the $$$...if a plug breaks, then you would have paid for it anyways right?
I got mine changed by the stealer at 35K ('05 FX4). I bought a set of one-piece Champion plugs online at sparkplugs.com and had the stealer use the non-breakable plugs. In removing the original plugs, two broke despite following the TSB from Ford. Since I was under 36K, the truck was on warranty. The cost was $205 to change the plugs (including broken) plus ~$110 for the new Champion plugs. PS...when plugs break there is in the TSB a method for removing the broken plugs...heads don't need to be removed etc...
