My pass side front axleshaft is grinding on the I beam (is that what you call it?) I was wondering about the alignment of the radius arms since I put a 4' lift kit on it. ANd yes the brackets were off about 1/4th of an inch. I welded the holes closed and re drilled them and they are perfect now. yet still the axleshaft grinds in 4wd.
What would cause this? I mean if I push the driver side I beam forward when the radius arm and spring are off, it make some clearance, but not much.
Is it possible the brackets from the kit are bent in some way? Some way that I couldn't see?
