Air Pump Eliminator Kit
Old Feb 3, 2011 | 10:55 PM
86F150302's Avatar
86F150302
Originally Posted by ratio411
I'm sure you guys know this, but for those that might not:
If you eliminate the air pump, you MUST eliminate the cats.
Not true.
The smog pump pumps fresh air into the cats to help pass emissions.
I would go with the Auto specialties 025030.
Old Feb 3, 2011 | 10:56 PM
mr_malina's Avatar
mr_malina
Originally Posted by 95F150Guy
You can save yourself some money and just gut the air pump. Thats what I did. I re-lubricated the bearings at the same time and welded the ports shut. It's basically just an idler pully now.
I was afraid I was going to break it trying to get it open. Any tips?
Old Feb 4, 2011 | 07:00 AM
rla2005's Avatar
rla2005
This might help: Fullsize Bronco.com - Dissecting the E5TE-DB smog pump
Old Feb 4, 2011 | 07:25 AM
hav24wheel's Avatar
hav24wheel
Originally Posted by raptor1971
I heard the 5.8 you do not need the bypass pulley because the engine is wider and should not throw the belt.
Nope, I had major issues keeping a belt on mine without the bypass pulley.. It worked fine with a new belt, but after 500 miles it would jump.
Old Feb 4, 2011 | 07:31 AM
pc_2000's Avatar
pc_2000
You can have an air pump without cats, although it is a huge waste, but you cannot have cats without the air pump (on a system engineered to include an air pump).
I can't speak for anyone else here, but I never heard that. What's the reasoning behind it?
Old Feb 4, 2011 | 07:57 AM
rla2005's Avatar
rla2005
I removed the air pump (very noisy) on my '92 F350 w/5.8L engine two years ago. I have been running a shorter belt since then with no issues. I also replaced the tensioner and pulley at the same time.
Old Feb 4, 2011 | 10:46 AM
lmd91343's Avatar
lmd91343
The hotter the environment, the faster a chemical reaction will take place. The catalyst (platinum) is on a screen in the cat that the exhaust passes thru.
The catalytic converter starts off as cold, it cannot work effectively. When the cat is cold the AIR pump takes fresh air, pushes it through a dedicated passage in the cylinder heads, and injects it into the cat to heat it.
If the cats are not warm, the cats cannot do their chemical magic, they will not clean the exhaust, it will clog the screen shorting its life and increase back pressure in the exhaust.
The very hot air and the exhaust produce the following reactions:
2NOx → xO2 + N2
2CO + O2 → 2CO2
CxH2x+2 + [(3x+1)/2]O2 → xCO2 + (x+1)H2O
Old Feb 4, 2011 | 11:00 AM
pc_2000's Avatar
pc_2000
2NOx → xO2 + N2
2CO + O2 → 2CO2
Cool. Good to know.
Old Feb 4, 2011 | 07:53 PM
93bronco89's Avatar
93bronco89
Thank you ross, I think that it would be easier to put a smaller belt on as well. I understand about the cats, I just rebuilt my 351 from the pan up and took all emissions off except for the EGR. Thankfully, hooker makes a header that allows you to run one. I was also able to find the belt routing and size diagrams that you were talking about. It is 84.5''
Old Feb 4, 2011 | 08:13 PM
CJM8515's Avatar
CJM8515
So, this whole air pump deletes a bad thing IF you still have intact cats. I have them but theres nothing in there..
Old Feb 4, 2011 | 08:32 PM
rossijd's Avatar
rossijd
It's sure not gonna hurt anything if you have gutted your cats. The cats will not do what they were intended to do without the air pump. I drove my truck with "good" cats and no air pump for several months with no issues. As was mentioned here earlier, there may well be long term effects to cats themselves if left that way (plugging/back pressure), . My truck doesn't have air pump or cats anymore.
Old Feb 14, 2011 | 04:00 PM
ratio411's Avatar
ratio411
Originally Posted by 86F150302
Not true.
Yes. It's true.
The air pump feeds clean oxygen to fire off the cats and make them burn.
It's like the reason you run oxygen with your acetelyne... It allows it to burn super hot. The cats (ones that are designed to burn with an air pump) must have that oxygen to burn off soot and hydrocarbons trapped in the cat. If the air pump is disabled, the cat will clog up and cause a huge obstruction in the exhaust flow.
It might not happen right away, and performance lost will be over time, so may not be noticeable at first, but the cats will clog up, performance will suffer, and eventually the cats will be ruined and can clog to the point of serious drivability issues.
Old Feb 14, 2011 | 04:03 PM
  #28
ratio411's Avatar
ratio411
If the cats are gutted or removed, the air pump is doing absolutely nothing and can be removed. To have an air pump with cats gutted/gone is a total waste of the pump's reason to exist.
Old Mar 4, 2011 | 03:30 PM
  #29
eggman95's Avatar
eggman95
Question
I just bought a 93 f150 custom with the 302 in it. I was just wondering besides the air pump what else can I remove off of the engine I want to clean up my engine bay?
Old Mar 4, 2011 | 03:37 PM
  #30
503racing's Avatar
503racing
try a beltfrom a jeep 4.0 (mine from an 05 4.0)used it on mine to bypass pump on a 92 302. worked
