Sponsored by: Real Truck
Map light question
Old Jul 14, 2008 | 07:28 AM
Edkajo's Avatar
Edkajo
Map light question
I've tried a search but only found problems with the dome light portion.My interior dome light and cargo light work fine but both map lights will not go on. Since I'm not an experienced electrical guy I've only checked the bulbs and the plug. They are fine.There is no indication in the manual if the maps are on a seperate fuse/wire from the dome so I'm at a loss of where to go next. I'm thinking there may be something wrong in the assembly itself since power is fine to the dome and not making it to the maps but I'm only guessing and thought I'd ask if anyone else has had a similar problem or another suggestion on what the cause may be.
It's a 2003 f350 Supercab 7.3
Old Jul 14, 2008 | 09:41 AM
rjmay's Avatar
rjmay
I had some problems once when I removed the light and I think the ground is from the mounting screws of the fixture.
I would try troubleshooting with a separate ground wire first.
