Ohm readings
Old Jul 13, 2008 | 05:20 PM
just-n-time's Avatar
just-n-time
Ohm readings
Another question, I was sitting at my work bench and took the three coils I have and decided to do an ohms reading so I placed the red lead of my digital meter in the center and took readings from both positive and negative post this is what I got, FIST COIL 138.6 ON BOTH POLLS, second coil gave 7.15 on both and the third was 10.80, my question is, dose this mean anything? The black lead was placed on each post to obtain these readings.
Old Jul 13, 2008 | 07:03 PM
JimsRebel's Avatar
JimsRebel
To test a coil you need to check the resistance of the primary and the secondary windings. The coil negative post is the common point to both the primary and the secondary windings. You will hook up the black lead of your ohm meter to the coil negative. To test the primary touch the red lead to the coil positive post, to test the secondary windings touch the red lead to where the coil wire output connects. In an older round coil you will see about 1.5-2 ohms in the primary. In a newer style square coil you will have about .5 ohm in the primary windings. The secondary windings have high resistance due to more winding which is how the voltage is stepped up. Look for 7000-10,000 ohm in the secondary. The exact reading is not that important, just something close.
Good luck
Old Jul 13, 2008 | 07:10 PM
JimsRebel's Avatar
JimsRebel
more info here with nice pic
Ignition Coils
Old Jul 14, 2008 | 01:30 PM
just-n-time
thank you jim
Old Jul 16, 2008 | 08:37 PM
just-n-time
well after rechecking the coils I am even more confused than before, on the two ford style coils I had this from neg post black test lead to bat one gave me 1.23 the other was 2.02 then placed the red lead to the secondary poll coil to distributor and got 8.98 and 7.23 so I guess they are bad?
Old Jul 16, 2008 | 09:24 PM
JimsRebel's Avatar
JimsRebel
they are most likely ok. the 2.02 one might have an internal resistor
Old Jul 16, 2008 | 09:47 PM
fmc400's Avatar
fmc400
MSEE
The 8.98 and 7.23 were probably in the Kohm scale; did you check? What the number on the scale\display means depends on the scale you are set to; unless it is an auto-ranging in which case it will tell you.
Old Jul 17, 2008 | 04:14 PM
just-n-time
yes I did check it was on K ohm
Old Jul 17, 2008 | 05:54 PM
fmc400's Avatar
fmc400
MSEE
Then it's fine.
Old Jul 17, 2008 | 08:33 PM
just-n-time
thank you for the confirmation
Old Jul 23, 2008 | 08:55 PM
just-n-time
found the trouble the napa ignition module was bad, replace it with a good unit I had all is well.
cjben
Feb 14, 2011 01:54 PM
2classics
Dec 10, 2010 12:23 PM
Cbronwen16
Nov 11, 2010 09:34 PM
ejohns06
Nov 6, 2008 09:22 PM
richardfalco
1997 - 2003 F150
Sep 17, 2008 04:13 PM
