My A/C started blowing warm..after checking the high side and low side pressures it was determined that the compressor was bad. I replaced the compressor, accumulator, and orifice tube. No sign of "black death".
After replacing everything and recharging my front AC is blowing at 58 degrees at idle. Pretty good it is over 100 degrees here, but when I turn on the rear AC the air blows 70 degrees.
My high side reading is 265 and the low side reading is 50 at 100 degrees.
