Replacing Mains without pulling motor?
Old Jul 12, 2008 | 12:47 PM
870's Avatar
870
1989 F-150 4x4 4.9L
Is it very hard to replace the mains & rods bearings with motor still in trk?
I know all about jacking up the motor to remove the pan. Done that twice on 2 other trks to replace oil pumps. What I really want to know is how hard it is to slide the upper bearing out from the crank. Do they come out fairly easy?
Thanks, James
Old Jul 12, 2008 | 10:21 PM
Franken-Truck's Avatar
Franken-Truck
is it hard?
Yes! Yes it is
And it would be near impossible to measure the middle half of the bearing clearances. . .and you wouldn't be able to pull the crank to at least have it polished.
Old Jul 12, 2008 | 11:02 PM
99whiteford's Avatar
99whiteford
Originally Posted by Franken-Truck
is it hard?
Yes! Yes it is
I second this suggestion.Possible yes,,very smart or easy NO
Old Jul 13, 2008 | 12:31 AM
sconut1's Avatar
sconut1
I would not recommend that you attempt this. I've been party to attempts like this when I was in the used car business. 100% failure rate (at least with us) after a short period of time if you use this method.
Old Jul 13, 2008 | 06:44 AM
Lazy K's Avatar
Lazy K
To answer your question all you have to do is put something like a flat head nail or bent piece of wire into the oil hole in the crank journal and rotate the crank to turn the bearing shell out. Is it wise? That`s up to you.
Old Jul 13, 2008 | 09:10 AM
dan91ford150's Avatar
dan91ford150
I think i bought a vehicle off of that lot once...
Old Jul 13, 2008 | 11:05 AM
icrman's Avatar
icrman
I've done it many times on big trucks, and heavy equipment. Very tight space to work in on these pick ups. If you can get the pan off and get the caps off it can be done.
Old Jul 13, 2008 | 12:45 PM
bad96's Avatar
bad96
im with all the others,
ive witnessed a few of these done and they all failed, some a few days others a few weeks
better off to pull it and do a rebuild if ya want lasting results
mudslingur
Apr 14, 2008 11:30 AM
SuperchargedRoadster
1997 - 2003 F150
Nov 2, 2007 11:01 AM
James82
22
Sep 14, 2004 11:52 AM
