Sponsored by: Real Truck
lift question
Old Jul 12, 2008 | 12:37 PM
Hollywoodf250's Avatar
Hollywoodf250
lift question
I have an 02 with the 7.3 in it with a 8 inch superlift kit on 37's.. i was wonder what would be the easiest and cheapest way to go up another 2-4 inches..
Old Jul 12, 2008 | 12:44 PM
DCSpecial's Avatar
DCSpecial
Hangers and shackles for the front.
Not sure what you currently run in the rear...but either larger springs, larger block or hangers and shackles.
Possibly need shocks all the way around.
And at that height you need crossover steering and to relocate your trac bar (not just a drop bracket, but relocate it to under the engine crossmember with new mounts that go from the driver's side of the crossmember to the top of the passenger side leaf pack using a longer adj. trac bar).
Driveline mods may be necessary as well (not sure if you front is already lengthened or not). A transfer case re-indexing ring and new crossmember is nice at 12" of lift.
Old Jul 12, 2008 | 01:03 PM
Hollywoodf250
so roughly how much am i looking at spending?
Old Jul 12, 2008 | 01:13 PM
DCSpecial's Avatar
DCSpecial
With crossover steering, trac bar relocation kit and adj. bar, shackles, and rear springs is over $2000
Then if you need shocks, opt for the indexing ring and crossmember, etc..
It adds up quick once you pass the 8-9" lift height to do it properly.
Old Jul 13, 2008 | 08:00 PM
rudedogii's Avatar
rudedogii
Just keep as is! If you want bigger tires just install some Bushwacker Cutout fenders.
You can go alot higher but you will have driveline and steering issues and with a higher center of gravity not very good offroader!
But if you have money no big problem, you can go as high as you want. There's always somebody out there who will be glad to take your money.
