S. California Chapter Join Chapter, Leader:
Welcome marcjay11
Old Jul 11, 2008 | 03:24 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Welcome marcjay11
Another new member - this has been a busy week!
Looks from the zip code that marc is from the Westside of LA - Number Dummy's old stomping grounds.
Glad to have you on board, marc.
Old Jul 11, 2008 | 03:39 PM
marcjay11's Avatar
marcjay11
I really appreciate the warm welcome!
I've been trolling around for a half hour now and I can see where this can become addicting.
Anyway - I've been researching towing with my 1999 4.6 (as Steve knows) and things don't look so good for old faithful. Most of what I read is simply to trade the thing for the 5.4. My truck has been a great workhorse, but is really a gutless tow vehicle.
I don't know if the warden (wife) is gonna be too happy about that.
Oh well...
Old Jul 11, 2008 | 03:41 PM
SteveBricks
FTE Emeritus
Addicting? Naw!
I seldom spend more than......well, never mind.
How much weight are you towing with your 99?
Edit: I remember from your intro post - 4000#, right?
Local, or long-distance?
Old Jul 11, 2008 | 04:15 PM
bpounds's Avatar
bpounds
Come on in Marc, kick off your shoes, sit a spell.
Tell us more about the trailer. Popup? Superlight TT? There is more to towing than just weight.
Bill
marcjay11's Avatar
marcjay11
I just looked it up. My trailer is 3,250 lbs. Max GVWR is 5,000.
Right at ol betsy's limit.
Some of my friends say to chip it and do exhaust. With 113,000 miles on it, It don't know if it's worth it.
Old Jul 11, 2008 | 04:19 PM
marcjay11's Avatar
marcjay11
Hi Bill,
It's a coachmen 19' light travel trailer. Really cool little guy for me, the wife, and a coupla dogs. No pop-ups or pop-outs. Looks like your truck will pull it in it's sleep!
Old Jul 11, 2008 | 04:22 PM
bpounds's Avatar
bpounds
On a gasser, I have never seen pipes or tuner pay for itself. Just not much bang for the buck.
But what can really make an *** kicking difference is gearing. You may well have 3:55 gears in the diff, and that's not too good for towing even with the bigger motor. You might want to consider going to 4:10 or even 4:30 gears. I guarantee you will notice the difference while towing. Maybe a modest loss of MPG when not towing, probably better MPG when you are towing.
Bill
Old Jul 11, 2008 | 04:43 PM
marcjay11's Avatar
marcjay11
I really appreciate the advise!
I'd very much like to get several more years out of this truck.
I'll check the manual and see what I have. I don't claim to know a whole bunch about gearing - wouuld 4:10 or 4:30 gears give a bit more low end torque?
For at lease the next year, our trips will be local (within 300 miles) but next year, we wanna hit the road!
The configuration as it is now is 60-65 mph on the flats no problem, but the hills, forget it! Also - I hit a head wind on I-15 through victorville and could hardly keep 45 mph.
Old Jul 11, 2008 | 04:55 PM
BradyCouchman's Avatar
BradyCouchman
welcome! a higher gear number will require a higher RPM to move the same speed, more RPM more power. i have 3.73 in my truck but then again i am running a 460CI motor and no overdrive so that helps me, but i even can tell when i tow up a hill that i wish i could get her moving a lil better...what i am trying to say is that 4.10s would be a good start...
Old Jul 11, 2008 | 05:07 PM
marcjay11's Avatar
marcjay11
Thanks Brady,
I've gotten some extremely valuable info here in a very short time. This weekend, I'll price the differential and decide if I want to part with the $$ or just save for a different truck.
Problem with that is I know myself. I'll get a bigger truck, then need a bigger trailer. Then a bigger line of credit to pay for the gas.
Very cool community that has been set up here, guys! I really appreciate your help.
Old Jul 11, 2008 | 05:08 PM
bpounds's Avatar
bpounds
The lower ratio gears will increase your motor RPMs at a given speed. These motors have peak HP and torque at the higher RPMs compared to earlier motor designs. In general, lower ratio gears will increase power to the wheels, but will decrease your maximum speed. A good gear shop can help you figure out what you need, or even if it's possible to get there with your truck. There are also some good calculators on the internet that will show you what your RPMs will be at different speeds with various gear ratios.
You can figure about $750 - $1,000 to regear. About double that if you have four wheel drive - you have to do both axles.
I predict you'll be wanting more truck eventually, so the question becomes whether it's worth it in the short term to regear. I was in much the same situation with an '04 F150. I had the 5.4 motor, pulling the same trailer I have now. It did the job okay. But I put more miles on the truck towing than not towing, so I took the plunge. Of course, if I had known diesel would be $5/gal a year later ... hopefully I would have still done it because it's worth it.
Bill
Old Jul 11, 2008 | 05:27 PM
marcjay11's Avatar
marcjay11
I think you're right. I'll need more truck to do any real traveling. More rpms will just burn out the engine faster. Looks like I'll have putt putt for a while and upgrade when I can.
What kind of trailer are you pulling?
Old Jul 11, 2008 | 05:28 PM
BradyCouchman
bills trailer: Fleetwood Pioneer, 23', 5,200#
according to his signiture at lest....he could be not telling the truth though
Old Jul 11, 2008 | 05:39 PM
marcjay11's Avatar
marcjay11
My bad. I could have read a bit more thoroughly.
Old Jul 11, 2008 | 05:40 PM
bpounds's Avatar
bpounds
Yes, that's still the one. It's probably a similar floor plan to yours Marc. But it's a dry weight of 4,000# and I've had it on the scale so I know it's about 5,200. We have grand plans for a 5th wheel in about 2 years. But price of a barrel of crude may alter those plans. The plan played into the decision to buy my current truck, including the long bed version. We'll see.
It's the best time to buy a truck that I've seen, ever. But it ain't such a good time to sell one.
