Oil Dipstick
Old Jul 11, 2008 | 03:19 PM
cts1954's Avatar
cts1954
Oil Dipstick
Hello
I got a good deal on a set of Sanderson center dump headers for my 52 flathead and they will interfere with the oil dipstick, I am sure this is a common problem so there must be some good solutions. I have looked for a flexible one but have not found the right one yet. Let me know if you have a good plan to fix this as I probably should be able to check the oil.
Thanks
Old Jul 11, 2008 | 05:38 PM
e william's Avatar
e william
I have the Sanderson rear dump headers and ended up taking two dipsticks and bending\welding them to a new contour to clear the header pipe. If you happen to find an aftermarket oil tupe that fits properly into the hole on a 54 239 y-block...please let me know also.
Ed
Old Jul 11, 2008 | 08:15 PM
cts1954's Avatar
cts1954
I see one on the Speedway web site that may work, it is flexible and is suppose to be for the 49-53 flatheads. $59.95 It may work but I would like to know for sure.
Old Jul 11, 2008 | 08:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The problem with flatheads is the tube screws in, so any bend in it needs to be able to clear the block/heads as you turn it in.
Old Jul 11, 2008 | 09:12 PM
cts1954's Avatar
cts1954
That is a good point I han't thought of, what do you think of the flexible one from Speedway. Probaly could screw it first then put the header on.
Old Jul 11, 2008 | 10:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Pricey, but it solves the problem...
