O2 sensors
Old Jul 11, 2008 | 02:38 PM
Roll Tide's Avatar
Roll Tide
O2 sensors
I have a 96 explorer 4x4 v6 and am getting three codes (P0135, P0141, P0155) about the O2 sensors. I can clear them and a little while later they're back and all at the same time. I find it hard to believe they would all go bad at the same time but I guess anything can happen. I did have another code that has not come back on yet and it was something about the engine coolant. I forgot to write down the code.
Old Jul 11, 2008 | 03:22 PM
Bear River's Avatar
Bear River
Former ******
Have you checked for intake leaks? Who says that you have an O2 sensor problem. Those codes are common when the upper intake manifold starts leaking.
Old Jul 11, 2008 | 03:53 PM
Roll Tide's Avatar
Roll Tide
I checked the codes and it said it was the Heated O2 sensor blah blah blah. Really don't remember it word for word.
Haven't checked for leaks but I will. Do you mean the hoses and/or the intake itself? Haven't heard any leaks. Would a bad catalytic converter cause these codes?
Thanks,
Steve
Old Jul 11, 2008 | 04:02 PM
Roll Tide's Avatar
Roll Tide
Just went outside and cranked it up to check for leaks and heard an odd noise. When I cranked it up it started making a howling noise. I could put my hand on the intake tube and feel the vibration of the noise. I disconnected the air filter and it got louder and was definitely coming from the intake tube. Patted the gas one good time and it stopped. Something funny's going here.
Thanks,
Steve
Old Jul 12, 2008 | 06:09 PM
aquanaut20's Avatar
aquanaut20
Thanks,
Steve
That is a sticky IAC valve, clean or replace.
Old Jul 13, 2008 | 12:40 AM
Bear River's Avatar
Bear River
Former ******
No, a bad cat will not cause O2 codes, though bad O2 sensors can cause a bad cat. O2 sensors should be replaced every 80,000 miles. The downstream O2 sensors (the ones behind the cat) do not need to be replaced unless they set a code.
A bad IAC valve and a bad MAF sensor can both cause strange noises in the intake. I would check the IAC valve. At least try cleaning it.
Old Jul 13, 2008 | 07:27 PM
BJWinter's Avatar
BJWinter
The howl is definitely the IAC. I chased that noise for a good month before I figured it out. Scary, scary sound. I would also reccomend checking for an upper intake leak. I was throwing those same codes, replaced the O2 sensors, and the codes still showed up. Haven't had a problem since I replace the intake gasket. Seems to be a pretty common problem with this engine.
Old Jul 17, 2008 | 02:59 PM
Roll Tide's Avatar
Roll Tide
I took the IAC off and it looked pretty nasty. Cleaned it out, installed it and the engine seemed to have a little more power. A couple days later the howl returned. It seemed to do it after I've idled for a period of time. I guess I will go ahead and replace it. Oh yea, cleared the codes. Didn't take'em long to come back though. If I go through the trouble of replacing the intake gasket I'm gonna go ahead and replace a tapping lifter also. Thanks for all the replies.
Steve
