Wipers Dead-GEM issue?
Old Jul 10, 2008 | 10:19 PM
pfeifer5's Avatar
pfeifer5
2001 F150 5.4L 4x4
My windshield wipers don’t work. The trucks been sitting for a few days, so I don’t really know when they worked last, or why they’ve gone out.
Fuse #11(30A) is OK since the washer fluid pump works. I don’t hear any attempt by the wiper motor to run, not even a relay click (dead quiet). I believe there’s something wrong with an onboard computer somewhere because with the key in the accessories position and the wipers switched on, the ABS idiot light in the dash comes on. Also the hood courtesy light doesn’t light anymore, but that same ABS idiot light in the dash comes on when I pop the hood. I tried disconnecting the battery (and turning on the headlights to bleed any residual voltage down), in an attempt to reset the GEM, but the problem remains. Mirrors, door locks, power windows, etc. all work OK. It's just the wiper motor isn't getting the instruction to run under any circumstance.
I’ve seen some posts about some kind of housing switch defect, maybe this is my problem:
Defect Summary:
VEHICLE DESCRIPTION: PASSENGER CARS, SPORT UTILITY VEHICLES, AND LIGHT AND MEDIUM DUTY PICKUP TRUCKS. A SWITCH LOCATED IN THE PLASTIC COVER OF THE WIPER MOTOR GEAR CASE COULD MALFUNCTION AND OVERHEAT, POTENTIALLY RESULTING IN LOSS OF INTERMITTENT WIPER FUNCTION, LOSS OF WIPER PARK FUNCTION, COMPLETE LOSS OF WIPER FUNCTION, OR IGNITION OF THE PLASTIC COVER MATERIAL. SWITCH MALFUNCTION IS MOST LIKELY TO OCCUR WHEN THE INTERMITTENT SETTING OF THE WIPERS IS BEING USED, OR WHEN SNOW OR ICE OBSTRUCTS THE BLADES FROM RETURNING TO THE "PARKED" POSITION AT THE BOTTOM OF THE WINDSHIELD. THESE VEHICLES WERE BUILT AT THE FOLLOWING ASSEMBLY PLANTS: ATLANTA PLANT FROM 2/11/00 THROUGH 7/31/00; CHICAGO PLANT FROM 2/14/00 THROUGH 8/4/00; KANSAS CITY PLANT FROM 2/26/00 TO 9/4/00; KENTUCKY TRUCK PLANT FROM 2/18/00 TO 8/31/00; MICHIGAN TRUCK PLANT FROM 2/23/00 THROUGH 8/3/00; NORFOLK PLANT FROM 2/21/00 THROUGH 7/27/00; WAYNE STAMPING AND ASSEMBLY PLANT FROM 2/25/00 THROUGH 8/15/00; AND WIXOM PLANT FROM 2/15/00 THROUGH 8/8/00.
I’m not sure what to try next and I want to take a trip this weekend.
Old Jul 11, 2008 | 11:05 AM
Holmesuser01's Avatar
Holmesuser01
Find out if all these circuits have a common ground connection and go from there.
The switch on the steering column is known to fail.
Check the plug on the wiper motor itself for corrosion.
Old Jul 11, 2008 | 11:28 AM
Franklin2's Avatar
Franklin2
The only thing I would know to do is go out to the fuse box under the hood and find the wiper/run park relay, and activate it manually to see if the wipers will work. If you find the yellow/white wire coming from this relay, and ground this wire, the wipers should run. That would test the motor and it's wiring.
The next question would be is it the GEM module or the switch in the column(the multifunction switch). Here's a bunch of junk from the service manual, but it looks like they use the scan too to troubleshoot if it's not a fuse.
Inspection and Verification
The wiper/washer system is a generic electronic module (GEM)/central timer module (CTM) controlled system.
Verify the customer concern by operating the wiper/washer system.
Visually inspect for the following obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
Hoses to windshield washer pump
Wiper/washer switch
Wiper linkage
Windshield wiper motor
Fuse(s) 11 (30A), 15 (5A), 20 (50A), 21 (50A), and 103 (50A).
Damaged wiring harness
Loose or corroded connector(s)
Circuitry open/shorted
If the concern remains after the inspection, connect the scan tool to the data link connector (DLC) located beneath the instrument panel and select the vehicle to be tested from the scan tool menu. If the scan tool does not communicate with the vehicle:
check that the program card is correctly installed.
check the connections to the vehicle.
check the ignition switch position.
If the scan tool still does not communicate with the vehicle, refer to the scan tool manual.
CARRY OUT the DATA LINK DIAGNOSTIC TEST. If the scan tool responds with:
CKT914, CKT915 or CKT70 = ALL ECUS NO RESP/NOT EQUIP, refer to Section 418-00 .
NO RESP/NOT EQUIP for GEM/CTM, go to Pinpoint Test G.
SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and carry out self-test diagnostics for the GEM/CTM.
If the DTCs retrieved are related to the concern, go to the GEM/CTM Diagnostic Trouble Code (DTC) Index to continue diagnostics.
If no DTCs related to the concern are retrieved, proceed to Symptom Chart to continue diagnostics.
GEM/CTM Diagnostic Trouble Code (DTC) Index DTC Description Source Action
B1302 Accessory Delay Relay Coil Circuit Failure GEM REFER to Section 501-11 .
B1304 Accessory Delay Relay Coil Circuit Short to Battery GEM REFER to Section 501-11 .
B1313 Battery Saver Relay Coil Circuit Failure GEM/CTM REFER to Section 417-02 .
B1315 Battery Saver Relay Coil Circuit Short to Battery GEM/CTM REFER to Section 417-02 .
B1317 Battery Voltage High GEM/CTM REFER to Section 414-00 .
B1318 Battery Voltage Low GEM/CTM REFER to Section 414-00 .
B1322 Driver Door Ajar Circuit Short to Ground GEM/CTM REFER to Section 417-02 .
B1323 Door Ajar Lamp Circuit Failure GEM/CTM REFER to Section 413-01A .
B1325 Door Ajar Lamp Circuit Short to Battery GEM/CTM REFER to Section 413-01A .
B1330 Passenger Door Ajar Circuit Short to Ground GEM/CTM REFER to Section 417-02 .
B1340 Chime Input Request Circuit Short to Ground GEM/CTM REFER to Section 413-09 .
B1342 ECU Is Defective GEM/CTM REFER to Section 419-10 .
B1352 Ignition Key-In Circuit Failure GEM/CTM REFER to Section 413-09 .
B1355 Ignition Run Circuit Failure GEM/CTM REFER to Section 211-05 .
B1359 Ignition Run/Acc Circuit Failure GEM/CTM REFER to Section 211-05 .
B1365 Ignition Start Circuit Short to Battery GEM/CTM REFER to Section 211-05 .
B1371 Illuminated Entry Relay Circuit Failure GEM/CTM REFER to Section 417-02 .
B1373 Illuminated Entry Relay Short to Battery GEM/CTM REFER to Section 417-02 .
B1398 Driver Power Window One Touch Window Relay Circuit Failure GEM REFER to Section 501-11 .
B1400 Driver Power Window One Touch Window Relay Circuit Short to Battery GEM REFER to Section 501-11 .
B1405 Driver Power Window Down Circuit Short to Battery GEM REFER to Section 501-11 .
B1410 Driver Power Window Motor Circuit Failure GEM REFER to Section 501-11 .
B1426 Lamp Safety Belt Circuit Short to Battery GEM/CTM REFER to Section 413-01A .
B1428 Lamp Safety Belt Circuit Failure GEM/CTM REFER to Section 413-01A .
B1431 Wiper Brake/Run Relay Circuit Failure GEM/CTM REFER to Symptom Chart.
B1432 Wiper Brake/Run Relay Circuit Short to Battery GEM/CTM GO to Pinpoint Test A .
B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure GEM/CTM GO to Pinpoint Test C .
B1436 Wiper Hi/Low Speed Relay Coil Circuit Short to Battery GEM/CTM GO to Pinpoint Test C .
B1438 Wiper Mode Select Switch Circuit Failure GEM/CTM REFER to Symptom Chart.
B1441 Wiper Mode Select Switch Circuit Short to Ground GEM/CTM REFER to Symptom Chart.
B1446 Wiper Park Sense Circuit Failure GEM/CTM GO to Pinpoint Test D .
B1450 Wiper Wash/Delay Switch Circuit Failure GEM/CTM REFER to Symptom Charts.
B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM/CTM REFER to Symptom Charts.
B1458 Wiper Washer Pump Motor Relay Circuit Failure GEM/CTM GO to Pinpoint Test E .
B1460 Wiper Washer Pump Motor Relay Coil Circuit Short to Battery GEM/CTM GO to Pinpoint Test E .
B1462 Safety Belt Switch Circuit Failure GEM/CTM REFER to Section 413-09 .
B1466 Wiper Hi/Low Speed Not Switching GEM/CTM GO to Pinpoint Test C .
B1467 Wiper Hi/Low Speed Circuit Motor Short to Battery CTM GO to Pinpoint Test B .
B1473 Wiper Low Speed Circuit Motor Failure GEM/CTM REFER to Symptom Chart.
B1476 Wiper High Speed Circuit Motor Failure GEM/CTM REFER to Symptom Chart..
B1483 Brake Pedal Input Circuit Failure GEM REFER to Section 308-07A .
B1485 Brake Pedal Input Circuit Battery Short GEM REFER to Section 308-07A .
B1577 Lamp Park Input Circuit Short to Battery GEM/CTM REFER to Section 413-09 .
B1610 Illuminated Entry Input Short Circuit to Ground GEM REFER to Section 417-02 .
B1840 Wiper Front Power Circuit Failure GEM/CTM GO to Pinpoint Test A .
P0500 Vehicle Speed Sensor Malfunction GEM REFER to Section 308-07A .
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure GEM REFER to Section 413-01A .
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit to Battery GEM REFER to Section 413-01A .
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure GEM REFER to Section 308-07A .
P1815 Transmission 4-Wheel Drive Mode Select Short Circuit to Ground GEM REFER to Section 308-07A .
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure GEM REFER to Section 308-07A .
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit to Battery GEM REFER to Section 308-07A .
P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure GEM REFER to Section 308-07A .
P1826 Transmission 4-Wheel Drive Low Clutch Relay Short Circuit to Battery GEM REFER to Section 308-07A .
P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure GEM REFER to Section 308-07A .
P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit to Battery GEM REFER to Section 308-07A .
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure GEM REFER to Section 308-07A .
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit to Battery GEM REFER to Section 308-07A .
P1838 Transmission Transfer Case Shift Motor Circuit Failure GEM REFER to Section 308-07A .
P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure GEM REFER to Section 308-07A .
P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure GEM REFER to Section 308-07A .
P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure GEM REFER to Section 308-07A .
P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure GEM REFER to Section 308-07A .
P1866 Transmission Transfer Case System Concern - Servicing Required GEM REFER to Section 308-07A .
P1867 Transmission Transfer Case Contact Plate General Circuit Failure GEM REFER to Section 308-07A .
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure GEM REFER to Section 308-07A .
P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short to Battery GEM REFER to Section 308-07A .
P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit GEM REFER to Section 308-07A .
Old Jul 11, 2008 | 06:21 PM
pfeifer5's Avatar
pfeifer5
Wow, thanks. I'll look that over.
I lied about no relay activity, actually it is clicking, and I swapped it out with an identical relay, but still no motor run.
I'll be digging into the motor tomorrow I guess. Anyone know how tuff an R & R is for this one?
Old Jul 30, 2008 | 06:21 PM
pfeifer5's Avatar
pfeifer5
Fixed
https://www.ford-trucks.com/forums/7...ing-fixed.html
phoneman91
64
Feb 2, 2025 05:40 PM
truck157
1997 - 2003 F150
Jul 20, 2021 08:08 AM
tom18287
1997 - 2003 F150
16
Dec 12, 2016 07:28 PM
Rockledge
1983 - 2012 Ranger & B-Series
17
Oct 30, 2015 08:19 AM
Monzter Kuztomz
Jul 18, 2011 11:18 AM
