Hi guys, been very busy, about to fit brake system, anyone have any diagrams, to work to , i have disc front drum rear, dual m/c & booster , also adjustable prop/valve & 2lb check valve, i have looked on cpp site , where i have had the m/c booster from, they have 2 set ups but still not to clear which one to use, any help appreiciated, cheers Kev, still raining ! uk.
cheers , how to check if residual valve fitted , will ask bobs f100 who supplied it to me, they sent me the m/c booster, & prop/valve & residual valve, so maybe does not have one fitted in m/c, Kev. will try to put some pics on soon.
As long as you are keeping the m\c and booster on the firewall, you don't need the 2lb residual valve for the front disc brakes. The 2lb residual valve is only required to prevent the brake fluid from draining back to the m\c when it is located in the stock location (under the floor boards) where it is at the same level and sometimes even lower than the calipers.
Rick
