1982 TTB 44 Question
Old Jul 9, 2008 | 04:25 AM
AKFORD4x4's Avatar
AKFORD4x4
I read somewhere that the 1980-82 TTB dana 44 front axle DOESN'T have the C-clip design holding in the shafts, is this true, wouldn't this make is a much more desireable TTB 44 to have?.
Old Jul 9, 2008 | 06:39 PM
Franklin2's Avatar
Franklin2
Some people think no type of TTB is desirable. I have never heard of c-clip problems with the TTB's. In fact, I didn't know they had c-clips? How would you get the axles out? There is no access cover on a TTB axle to get the c-clips out?
Old Jul 9, 2008 | 07:51 PM
82F100SWB's Avatar
82F100SWB
There is a C-clip on the passengers side axle... You have to drop the diff off of the beam to pull it out, sometimes this is required to change the inner u-joint on the passengers side....
On the 80-82 trucks, they run a bearing that's pressed on the shaft with a bolt on retainer, much like a 9" rear has. Much more desirable for servicing, and for a locker/etc.
Old Jul 9, 2008 | 10:47 PM
Franklin2's Avatar
Franklin2
I guess that would not be too bad since you have the slip yoke on that side that you could pull apart and sit it on the ground.
Old Jul 10, 2008 | 06:25 AM
AKFORD4x4's Avatar
AKFORD4x4
Hey
I take it your one of those guys who thinks the TTB is Undesireable?. Its all in what you want it for, I already have a One ton straight axled rig that I use for rocks and knarly stuff so I dont need to do an SAS on the truck I'm asking about. I'm so sick of hearing "TTB is junk, SAS SAS etc etc, Yeah I know for most flex, durability, strength, dependability that a straight axle is the way to go, however that wasn't my question, I'm building a pre runner truck, I want a new project, something I havn't done before, I've built enough rock crawlers and mud boggers, I want to do a pre-runner now and if you noticed the TTB is the most popular pre-runner set up. Anyway, to the guy who answered my question, thank you.
