Engine Flywheel
Old Jul 8, 2008 | 10:44 PM
bob wny's Avatar
bob wny
Smile Engine Flywheel
Hello I am new to the forum. I own a 1993 Ford F150 4x4 with a 302, automatic trans. I bought a 5 speed 4x4 setup from a 1994 F 150 with a 300 and all the research I have done I have found that everything that I got from the donor truck will interchange. I do have the 11 inch clutch assy. My question is the only part that I have found that is different is the flywheel. What is the actual difference between the two flyheels. I didnt know if the bolt pattern was different or exactly what. They both have the same 164 tooth ring gear. I dont have the automatic transmission out of the truck yet. I dont know if I need to try to locate a new flywheel before I get the truck apart. Any help would be greatly appreciated.
Old Jul 9, 2008 | 04:36 AM
EPNCSU2006's Avatar
EPNCSU2006
You'll need a 302 flywheel from a similar year model truck (87-96). The 302 flywheel has a built-in imbalance, while the 300 flywheel has none.
mh822
102
Dec 5, 2025 03:49 PM
460fordf150
Sep 4, 2009 11:43 AM
bheneee
Modular V8 (4.6L, 5.4L)
Jul 21, 2009 09:31 PM
79F150EFI
Jul 5, 2006 08:29 PM
stangfan78
Engine Swaps
Jul 10, 2005 02:35 PM
