Did this a month ago, talked about using herculiner before but decided not to. Used a new paint by rustoleum called "hammered" If it last a couple years I'll be happy.
It looks black in the pic but is actually a dark grey metalic.
that looks good on the truck Bill. and i think paint was a better choice than herculiner cause if you ever wanted to take it off i would not want to be in you skin,
Yes, and less money also.. under 11 dollars a quart at Lowe's. I used just less than a quart. It has a nice rippled finish to it, looks thick.
Looks good! I need to do something on my right rear quater panel. It's getting all chipped up from rocks, sand and road debris.
I know flares aren't for everyone, but I will tell you that with wide tires, the do more to help than the flaps I had before. Even helps with the rocks flying back to the boat.
