Maintenance/Repair Estimate
Not sure if this is in the right forum list or not. I have an '00 F250 SD 2WD 5.4ltr w/75,000 miles. Dealership says I need new upper/lower ball joints both side, new steering linkage both sides, new shocks all around and an an alignment. Quoted $2,258.oo for parts and labor. Thoughts? Does this stuff last longer/shorter than 75K? I drive it dailey and tow a 21' boat on the weekends. Thanks.
Welcome to FTE. As Jim stated, that price sounds high. Quite probably way high. I don't know how mechanically inclined you are, but if nothing else you could probably change the shocks yourself. I'd recommend getting an estimate from an independent shop and see if you can't cut that price at least in half.
Has the steering linkage been greased on a regular basis? I wouldn't be surprised if you only had to replace part of what the dealer recommended. If you're still running the factory shocks, change those now. You'll be amazed at the difference in the ride.
