painting heater box?
Old May 15, 2002 | 10:27 PM
Ferrite's Avatar
Ferrite
I'm in the process of restoring the interior of my 79 F-100.
Among other things, I removed the heater box and core.
(standard hi/lo heater, no a/c)
My question is regarding the metal side of the heater box.
The side of the metal that faces inward was quite rusty.
I have sanded away all of it so it's back to bare metal.
Before I put it all back together, I was thinking about painting
it to avoid further corrosion. Then I got to thinking....did Ford
leave it unpainted for a specific reason? My concern is that when
I use the heater, I will be smelling the paint. I'm worried that
the heat will scorch it, I guess, making a nasty odor. I could use
high heat (engine) paint, but that's rated at 500 degrees and needs
to get that hot (or close) in order to cure it. My experience has
been that without curing, it stays very soft. And I don't think
the heater would supply enough heat to cure it properly.
I know, I know....no one will ever see it, I just am looking to
avoid more rust in the future. When i finally put everything back
together, I want it to last another 20 years or more.
So....paint or no paint? If yes to painting...high heat or regular?
Thanks for reading, I appreciate any feedback.
-Ferrite
Old May 15, 2002 | 10:53 PM
Mil1ion's Avatar
Mil1ion
Give it a coat of Zinc Chromate.
It's yellow, but nobody will see it and it will prevent further rusting and cures well.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 15, 2002 | 11:10 PM
Ferrite's Avatar
Ferrite
ah, thanks
I didn't even think about that.
I'm not familiar with what "chromate" is, but I'm guessing
it's similar to (or the same as) zinc primer?
I'll ask for it at the autobody supply store.
Thanks again.
-Ferrite
Old May 27, 2002 | 07:50 PM
TomC's Avatar
TomC
Zinc chromate was taken off the market due to EPA problems. You can use cold galvanizing spray, it will do fine. Any good enamel paint will work as well. I painted the inside of my AC/heater with good quality black spray paint without problems. Ford doesn't paint them as it would cost extra money during production. Older trucks were painted thru out but that was 1950s and earlier.
TomC
Old May 30, 2002 | 11:31 PM
TomC's Avatar
TomC
