Injectors testing ?
Old Jul 8, 2008 | 12:23 PM
carkrazd's Avatar
carkrazd
Injectors testing ?
Hi Folks,
I haven't posted for some time. Tons of work going on.
I still have a problem with my 95. I believe one or more of my injectors
are not firing right. Can any one tell me how I can test each one to see which one could be bad?
Good news, my wife and I now have three 7.3 trucks. We picked up an '02
Excursion in Jan. with 36,000 on it
Old Jul 8, 2008 | 01:19 PM
secondarychaos's Avatar
secondarychaos
Congrats on the trucks!
I think you want a buzz test, but i also believe you can test them simply with a ohm meter??? lemme keep looking and if no one has answered for ya hopefully i'll have something.
Old Jul 8, 2008 | 02:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
You got the BUG very quickly, didnt you? , congrats for the 3 trucks and for that low mileage EX. enjoy them.
Old Jul 8, 2008 | 03:58 PM
carkrazd's Avatar
carkrazd
well not real quickly my first 4x4 crew cab came in 97.
Old Jul 8, 2008 | 04:02 PM
carkrazd's Avatar
carkrazd
Has anyone used auto enginuity on a 95 psd ?
My A.E. seems to not want to scan this truck ---
Possible computer flash needed ?
Old Jul 9, 2008 | 10:30 AM
MagKarl's Avatar
MagKarl
You might need your PCM reflashed to work with AE. I need to get mine done as well so I can get a scan guage. Even without AE, you should be able to find the bad cylinder pretty easily. There are 4 legs to the injector/GP harness that plug into the valve cover gaskets. Each one controls two cylinders. There are 5 pins in each, center is common, check resistance between the middle and the others, should be a couple ohms at most. #1/5 are GP's, #2/4 are injectors. If they ohm out ok, unplug one leg at a time and start it until you find the one that makes the least difference. Then remove the valve cover on that side and unplug those two injectors one at a time. The one that makes the least or no difference when unplugged is probably the worst one. I don't know if it matters or not, but I shut it down between plugging/unplugging steps. With both valve covers off, you can also watch it idle and see if all injectors are spitting oil equally and watch for any bad oil leaks around the injector body.
