Help out a 6.0 Guy
Old Jul 8, 2008 | 08:30 AM
Sarge261's Avatar
Sarge261
Help out a 6.0 Guy
Hey Guys,
I am looking for a little guidance on a 00 7.3 4x4 CC truck. I am going to change the fuel filter in it in the a.m. Havent seen the truck yet so I am not sure if there are 2 like the 6.0 Are there any tricks to doing these like the 6.0 or pretty straight foreward. I was looking for a Tech folder but couldnt seem to find it. Thanks for the help guys.
Sarge
Old Jul 8, 2008 | 08:33 AM
Smokin''s Avatar
Smokin'
Smokin
Sarge, if the truck is stock, there is only one.
Remove the plastic black cover that says "powerstroke 7.3" (err, I think that's what mine says) and you'll see it. It's on the very top of the motor, pretty hard to miss.
Very easy to change out. I'll see if I can find the link to the procedure someone has already typed up.
Edit. Found it. Here ya go: http://guzzle.rbmicro.com/ffilter.html
Old Jul 8, 2008 | 08:34 AM
F350-6's Avatar
F350-6
We don't help your kind here.
Just kidding. The 7.3 swap is much easier than the 6.0, and we only have one of them. Pay attention to which way the bevel gasket faces. That's about the hardest part. You do need to be aware that some aftermarket filters have the lid permanently attached to the filter so the lid becomes disposable. If that's the case you'll either need to go back with the same type or get a new lid.
Here's a link on the change with pics. Welcome to guzzle's PSD Fuel Filter Change Web Page
Old Jul 8, 2008 | 08:35 AM
Orezona's Avatar
Orezona
Just make sure you get that beveled o-ring off the cap and put the new one on. And drain the bowl before you take the cap off.
Orezona's Avatar
Orezona
Dang you guys are up and typing fast!
00Dave's Avatar
00Dave
The only filter I have changed on mine is on top of the motor in a black housing, kinda like yours. I used a pair of channelocks with the handles spread apart and removed the lid that way. There is a yellow valve on the passenger side, back, bottom of the filter housing that you will need to open to let the fuel drain prior to removing the lid. You should also have a new gasket with the filter. Pay attention to the one you remove because they are bevelled and need to be installed the same way. Hope this helps a little.
Old Jul 8, 2008 | 08:37 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome here Sarge, I think you have your answer.
Looks like you have a nice truck in your sig. Lots of Banks stuff.
Old Jul 8, 2008 | 08:38 AM
Smokin''s Avatar
Smokin'
Smokin
And all this time you had us convinced that you are a slow typer.
Chicken peckin' at lightning speed.
Old Jul 8, 2008 | 08:41 AM
F350-6's Avatar
F350-6
I don't know about that Lisa. You replied and went back and did your edit before I could finish.
Old Jul 8, 2008 | 08:43 AM
mueckster's Avatar
mueckster
One other note: Someone posted before about using a "little" oil on the filter gasket, instead of diesel fuel, to allow it to seat properly. It may apply only to certain brands of filters, but wouldn't hurt to do anyway.
Old Jul 8, 2008 | 08:48 AM
superduty4x4's Avatar
superduty4x4
6.0 guys can't even catch a break! Everyone has you pretty well lined out it sounds like. When draining the fuel, add a piece of rubber hose to the stock drain line to drain it into a can or something to keep it from going all over the truck- the drain line is hard to see until you know it's there, it's on the passenger side of the block. I found mine by cracking the drain valve briefly then crawling under and watching for where the drip was coming from. Without draining the fuel you'll have a helluva time getting the cap off.
Old Jul 8, 2008 | 10:41 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
You'll want a 13mm deep socket to get those "bolts" off. They're recessed pretty good, and just deep enough so that a standard depth socket will just barely catch the flats.
Old Jul 9, 2008 | 11:23 AM
Sarge261's Avatar
Sarge261
Thanks for all the help. I have an account with a Motor Craft dealer so only ford parts for this guy Anyway I guess the only question is to oil or not to il the filter oring.
Again I thank you
Sarge
Old Jul 9, 2008 | 11:29 AM
F350-6's Avatar
F350-6
Again I thank you
Sarge
If it's the beveled gasket just use diesel fuel. If it's a flat gasket like the new (I believe wix) design, you need to use motor oil.
Old Jul 9, 2008 | 11:38 AM
Sarge261's Avatar
Sarge261
Is there anyway to prime the pump or just turn the key on and off a few times. I know on the 6.0 if you dont prime it it runs like poopie.
Sarge
