Problem with my front axle
Old Jul 7, 2008 | 01:48 PM
Belize Off Road Team's Avatar
Exclamation Problem with my front axle
I have the famous ford front axle and it has a problem.
When i reverse, get out and look at the front it looks like the truck was kicked in the *****. So in other words, the top of the tire goes inward and the bottom goes out alittle bit.
Old Jul 7, 2008 | 02:15 PM
LilDuke's Avatar
LilDuke
Oh, you suffer from the same ailment my truck does. It's a combo of the design, and worn out springs(coil). Also possibly ball joints too.
Old Jul 7, 2008 | 08:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Actually the toe in will cause the front tires to get the / \ look all the time when you stop while backing up.
Any worn parts just makes it look worse/go farther.
Old Jul 8, 2008 | 05:34 AM
PLC7.3's Avatar
PLC7.3
Mine came from the factory like that...... since having a few alignments it has been removed........ unfortunately so has the nice soft ride. There was never any tire wear or driving problems when mine was like that either......
Old Jul 8, 2008 | 09:43 AM
Ok, so it just from worn ball joints, worn leaf springs? i'll have no front tires pretty soon. So what is the best recommendation for me to do to cure the issue?
And thanks for the info!
Old Jul 8, 2008 | 06:44 PM
Dave Sponaugle
Is the truck you are talking about 2 wheel or 4 wheel drive?
Old Jul 8, 2008 | 07:51 PM
LilDuke's Avatar
LilDuke
I assumed 2wd. All three of my trucks look/do that. None of the show excessive wear, but I also rotate once a year.
Old Jul 8, 2008 | 10:29 PM
AndysFords's Avatar
AndysFords
I'm assuming 4wd, his name is off road team. I remember when that axle first came out, a man down the road bought one of the first ones, I think an 80 or 81 model, and 2 years later the wheels were both cocked way over like that, he took it to Ford and they told him they didn't know how to fix it.
Old Jul 9, 2008 | 07:20 AM
Your right Andy, it is 4WD. And the angle of the tires is so excessive that one of the front tires is nearly bald!!!!! the other is not far behind!!!!!!!! Just from small amounts of reversing!
Old Jul 9, 2008 | 09:36 PM
Dave Sponaugle
How much clearance do you have between the spring and the bump stop?
Under 1" with the truck setting level?
I am going to bet on the front spring shackles being a lot of the problem.
The end that fails is up inside the frame, so you can not see any wear until you drop them out.
No need to remove anything except the two top shackle bolts, then raise the truck till you can see the top bushing.
Old Jul 13, 2008 | 09:39 AM
bleedin blue's Avatar
bleedin blue
you said it does it when reversing how about when going forward does the wheel straighten up?
