Repl'ing front axle shaft, recommendations?
Old Jul 7, 2008 | 12:51 PM
expy37at's Avatar
expy37at
Front end on a 2001 4x4 Expy is popping. Replaced ball joints and it still pops.
So I'm going to replace the axle shaft on driver's side.
Local Ford wants $428 and dealer won't discount.
Online they are about $345 and Carquest has rebuilt ones for $103.
I travel at night pulling a trailer so I need reliability.
Ideas on the best one to purchase?
Thanks!!!
Old Jul 7, 2008 | 01:15 PM
Gage2502's Avatar
Gage2502
Is the price at the dealer include labor? Or are you going to install it your self?
~Gage~
Old Jul 7, 2008 | 01:19 PM
expy37at's Avatar
expy37at
I'll be installing. We do all the work ourselves.
Old Jul 7, 2008 | 04:38 PM
slc10844's Avatar
slc10844
You might what to check the yellow pages. There are usually local shops that specialize in rebuilding drive shafts, axles, etc. Any chance it might be something other than the axle shaft?
Old Jul 7, 2008 | 07:27 PM
cbradford's Avatar
cbradford
I would check the pitman arm, as my 97 did the popping noise until I replaced pitman arm
Old Jul 7, 2008 | 11:18 PM
ToolTime's Avatar
ToolTime
Ok, before you begin replacing all these parts ask yourself a few questions. First, when does the popping occur? If it happens while turning, the pitman arm, or idler arm might pop occasionally, during a turn. If while turning under power or acceleration and a constsnt popping is heard, and felt by a possible jerking motion in the steering wheel from the inside front tire, then I would lean towards front CV joints. I have found many lube shops including the local dealerships lube techs neglect to ever lube the idler arm, thus resulting in premature wear on that piece. If the popping happens while going over a bump driving straight, the I would focus mostly on chassis parts; i.e. shocks, ball joints (uppers since you replaced the lowers),upper and lower a-arm bushings.
