Overdrive question
Old Jul 7, 2008 | 12:27 AM
TP83's Avatar
TP83
Overdrive question
I just got back from a camping trip and did 7 hours towing without it, now that is sometimes a good thing but on flat ground like most of the driving it would have been nice. why would my truck not engage o/d the whole time? it does have a 60tow setting but even on stock mode and even changing the truspeed nothing worked. the trans ran around 180 to 200 most of the time. on the way up it ran great until i hit redding where the hills started but i just figured it was best to not use o/d anyways. also on my way back right before the dinner stop the o/d off light was blinking and then it did that about 10 mins from home aswell. what kind of problems am i looking at? the truck will be going in to the shop because i would like to get this fixed before the next trip.
i think my next purchase is a wicked wheel because that high pitched noise from the turbo surge is killer without OD.
sorry for the long post and sorry to the fellow ford owner i got close to at 680, my trailer hit the bump on the turn and sent me all over the place, but thats not an excuse it was my fault.
Old Jul 7, 2008 | 06:11 AM
greedy737's Avatar
greedy737
Did you check for codes? Also the turbo will be louder with the WW in, but no surge!
Old Jul 7, 2008 | 07:41 AM
clux's Avatar
clux
The blinking OD light means it has stored a transmission code, get it checked out and you may have an answer to your transmission not shifting into OD.
Old Jul 7, 2008 | 07:44 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
O/D light flashing means something is going wrong with your tranny and a code will be stored. Any good tranny shop will have a reader and tell you what it was. Don/t forget, nothing on a vehicle ever fixes itself. Whatever the problem is/was will raise its ugly head again.
Old Jul 7, 2008 | 08:25 AM
HKusp's Avatar
HKusp
It could be something as simple as the ABS module on the rear axle, or it could be something more terminal. As was stated, get the codes read and lets go from there.
Old Jul 7, 2008 | 08:27 AM
Markadeck's Avatar
Markadeck
I didn't bring that up because he was saying how hard he had been working the POS transmission. Sorry.
Old Jul 7, 2008 | 11:51 AM
TP83's Avatar
TP83
It's getting checked out today but i forgot to mention that when i was towing through the hills the abs light did go on.
Old Jul 7, 2008 | 12:00 PM
Markadeck's Avatar
Markadeck
I'm trying to decide whether that makes me feel any better or not. I have my ABS light come on every 6 months or so for a few minutes and just ignore it and it goes away the next time I start the truck. But both times in all these miles the O/D light has started flashing it has resulted in major transmission failure.
Old Jul 7, 2008 | 12:17 PM
derekmj64's Avatar
derekmj64
I had the same problem with my truck... It started with the overdrive light flashing then next my truck started shifting really hard and the speedometer would jump +/- 5mph while driving. I could not figure it out so I took it to the dealer and they found it was the truspeed I had installed on my truck. They took it off and recalibrated my speedometer with their computer and I haven't had a problem since.
Possibly check the Truspeed or your VSS.
Old Jul 7, 2008 | 02:27 PM
TP83's Avatar
TP83
We checked the truspeed on the road, just put it into setting 2 which is how it was before we installed the tru speed. i'll find out soon enough i just need to get some time because this unpacking and physical therapy has really taken a lot of time.
Kimberguy
Dec 14, 2011 06:00 AM
akorcovelos
21
Oct 21, 2011 05:42 AM
eatont9999
Aug 14, 2011 09:57 AM
medic92
2004 - 2008 F150
Oct 2, 2007 09:06 PM
barracudamuscle
Oct 18, 2006 08:01 PM
