No topic thread,,, Part 2
Received 1,409 Likes
on
The holding tank was pumped out last fall Gerry.
The pump was burnt out and with a replacement now it seems like it`s a frozen under ground line. Rather than trying to thaw the entire 200 ft under ground line I`ll run a surface line making sure it drains so it doesn`t freeze. I did that once before one winter and it worked like a charm.
Aren't we due for an early spring soon?
Morris thats actually very easy to fix if its frozen. Chances are good it could be as well.
Take a bunch of garden hoses, string them out, throw the hot water on, and shove the hose down the line.
Do you have a pump stack at the end of the line, or is it just the line??
You might be surprised where it is or isnt frozen Morris. If the line was properly dug, it should be under the frost line till the last 15ish feet, where it would slope upwards to either the stack, or the exit.
Theres pretty much no way you would ever have 200 feet of line frozen, unless it was very extremely poorly installed.
Surface lines work ok too, Ive had to install those for guys time to time. Most of the time the hose trick (or a steamer line) works way better, way faster, and alot less work.
on
Hi Grant, sorry had to go back to work ! Rt 222 also called Road to nowhere! lol by the locals, is 1/4 mile off my road, Bird in Hand is just south of Lancaster, my place to Bird in Hand no more then 45 minutes!
Received 5,336 Likes
on
on
on
Haha good call gerry, I dont see it getting better anytime soon either!
I had an awesome cheat meal tonight, chinese food with ice cream for dessert, yummmay!
Ill feel it tomorrow though haha. Being on a half assed strict eating plan sure is nice sometimes, and cheat meal days are one of those times!
