E-450 Heater control problem
Old Aug 17, 2002 | 05:33 PM
ziomeks's Avatar
ziomeks
I have a Ford E-450 RV with a heater that does not seem to shut off. When the air control is set to "Vent" and the temperature contorl set to the coolest setting, the heat is pouring out of the vents.
Does anyone know if the heater lines are shut down via a valve if the controls are not in heat mode? Higher end vehicle like the Lincoln and Mercury's have such a valve.
Is there such things as plumbing diagrams for this vehicle?
Old Aug 17, 2002 | 06:14 PM
mantta's Avatar
mantta
Old Mar 5, 2026 | 06:10 AM
chasnchge's Avatar
chasnchge
1st Gear
This is exactly my problem in a 1999 E450. Did no one else ever have this problem? The AC seems to work okay, so don’t think it is the common defrost problem that receives all the replies.
Old Mar 5, 2026 | 08:48 AM
Don Ridley's Avatar
Don Ridley
The blend door actuator is broken. It directs air around or through the heater core. It can be tricky to replace. Look for a YouTube.
Diagram of the air flow is here:
https://www.ford-trucks.com/forums/1273073-easy-cheap-quick-fix-for-ford-defrost-vent-problems.html
andytan
2014+ Transit
Oct 6, 2023 10:51 AM
Larry115
Oct 10, 2021 11:48 AM
coxhaus
Sep 9, 2016 05:35 PM
1'stonraceday
26
Dec 17, 2012 03:11 PM
cwminard
16
Aug 26, 2004 11:20 AM
