Fuel Pump
Old Jul 5, 2008 | 01:18 PM
jtttj's Avatar
jtttj
Unhappy Fuel Pump
Help! I have a 1972 Fire Truck with a V8 534 CI engine. I believe the electric fuel pump, mounted out side the fuel tank 25' from the carb is bad. The numbers off the pump are:
Transister Fuel Pump
12V Grnd
Unit No A6988
U-Shin LTD
When I remove the fuel lines and connect a fuel line into a gallon of gas (in) and turn the key, I hear the sound of the plunger going up and down but no gas is exiting the pump.
Anyone know anything about this pump or what the correct PSI fuel pump should be?
Thank you, Jerry
jerry_s
Feb 18, 2015 11:07 PM
jerwiltho
Aug 15, 2013 04:00 PM
jerwiltho
Feb 21, 2013 09:08 AM
jtttj
Jul 5, 2008 09:03 PM
