2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
A/C leaks water on passenger side floor.
Old Aug 18, 2010 | 07:11 PM
lincolnfan's Avatar
lincolnfan
my 07 Nav floor is wetter than Niagra Falls!! I live in northern Il where it is hot and humid!
Old Aug 20, 2010 | 08:39 AM
function12's Avatar
function12
Never had an issue here in Houston.
Old Jun 23, 2011 | 10:56 PM
hjsimpson's Avatar
hjsimpson
River rapids!
Looks as though my ac might be doing the same thing. The last couple of days I thought there was something rolling around on the floor. I finally took the few seconds tonight and found the passenger side carpet is soaked, this is the first year it's happened at least that I have noticed. I will have to see if its definitely the ac that causing the issue. Every time I would make a left it sounded like river rapids flowing by!
Did the extra part of the hush panel work?
Old Jun 23, 2011 | 11:06 PM
Baumbach's Avatar
Baumbach
no the hush panel did not work, it helped, but most of the water comes from a leak or condensation on the drain pipe at the firewall.
Old Jun 23, 2011 | 11:20 PM
hjsimpson's Avatar
hjsimpson
Thanks for the quick reply....
So your saying there's nothing that can be done? Also was the hush panel just a snap in part?
This will be definitely be my last Ford product.. Love the ride but i have had way too may issues with my 07 Expy and previously my 02 Explorer.
Old Jun 23, 2011 | 11:28 PM
Baumbach's Avatar
Baumbach
There should be a fix to the lean, I have not looked into it a lot, but I am sure covering or wrapping it will insulation should stop it.
yes the hush panel is a snap-in.
Old Jun 23, 2011 | 11:30 PM
hjsimpson's Avatar
hjsimpson
Thanks! I will have to go and order the part. What did you mean by "There should be a fix to the lean?"
Old Jun 23, 2011 | 11:35 PM
Baumbach's Avatar
Baumbach
There should be a fix “to the leak” is what I meant to say, it, I just have not tried any yet, i.e. insulation
Old Jun 24, 2011 | 12:17 PM
trpltongue's Avatar
trpltongue
It's weird, I haven't had this problem since 2008. Shortly after I posted about it, the problem simply went away and hasn't come back. I'll have to check this summer to see if it returns and I just haven't noticed it. Pretty crappy design regardless.
Old Jul 14, 2011 | 05:43 AM
hjsimpson's Avatar
hjsimpson
The dealer suggested it may be a clogged drain for the AC. Does anyone have any tips on how to go about check for a blockage?
Thanks!
Old Jul 14, 2011 | 10:43 AM
gaffer222's Avatar
gaffer222
My mother's Mercury Mini van had this issue and there is a drain that comes out from the firewall in on the engine side. I carefully stuck a hanger in there and unclogged it. She has had no issues since.
Old Jul 14, 2011 | 11:35 AM
berry1234's Avatar
berry1234
Thanks!
Our trucks do not have the drain hose visible. Its an opening in the silver heat/sound shield on the passenger side of the firewall. It's a bad design. I don't know how you would stick a coat hanger up there with any accuracy.
Old Jul 14, 2011 | 12:20 PM
  #28
hjsimpson's Avatar
hjsimpson
Bad design is right! I'm so frustrated with this vehicle...
Is there a drain tube that can be accessed from under the glove compartment?
Old Jul 14, 2011 | 12:23 PM
  #29
berry1234's Avatar
berry1234
I don't think so but I could be wrong. Crawl under the truck with a powerful light and see if you can see the opening I mentioned. I know the water just drips out of the shielding opening on mine.
Old Jul 22, 2011 | 09:04 PM
  #30
hjsimpson's Avatar
hjsimpson
Well I gave it the ole' college try but no luck...... Anyone have an idea how much this is going to cost me?
