Sponsored by: Real Truck
tire size...
Old Jul 4, 2008 | 07:37 AM
weyland426's Avatar
weyland426
tire size...
I didn't see this in FAQ, but what is the max size of tires that will fit '08 F-350 4x4 without any fear of rubbing. Was thinking of upgrading the stock 275's to 295's??? Thanks.
Old Jul 4, 2008 | 08:58 AM
dougc's Avatar
dougc
Is that pretty much the same front suspension as an 05? If so, I think 315/70 17 (or the equivolent in a 18 or 19 inch wheel) would fit with out a lift or rubbing issues. 305s shoudl fit too, if you didn't want to go up to a full 35 inch tire.
Old Jul 4, 2008 | 09:03 AM
weyland426's Avatar
weyland426
The truck height looks the same as previous model years, but I'm not sure. The local tire store say's not to go over 295's but I sure would like 305's if I can get away with it. Thanks.
Old Jul 4, 2008 | 10:28 AM
dougc's Avatar
dougc
Ask the store to test fit and check for rubbing--you should be fine. I've got a 2005 crew cab fx4 with 315s and no issues.
