A/C not cold enough
Old Nov 4, 2002 | 10:27 PM
Hyperlite's Avatar
Hyperlite
A/C not cold enough
ac just doent blow cold enough friend told me he saw posting that hot water always goes through heater core and just gets vented, but there is ford part to bypass hot water from other ford car or truck , anybody know about this?
Old Nov 4, 2002 | 11:19 PM
steve83's Avatar
steve83
A/C not cold enough
What vehicle are you talking about? 80-up trucks don't need to bypass the heater core because the air doesn't pass thru it when you have the selector set to full cold. There IS an adjustment on that cable, but you'll have to specify the year & type first, though.
Old Nov 5, 2002 | 07:07 PM
Hyperlite's Avatar
Hyperlite
A/C not cold enough
sorry about that , truck is 99 superduty V10 crewcab 4x4
Old Nov 6, 2002 | 09:20 PM
steve83's Avatar
steve83
A/C not cold enough
Byeeee. My forte is '80-97 only.
Old Nov 6, 2002 | 11:08 PM
brown 4x4's Avatar
brown 4x4
A/C not cold enough
OK, I know this works for pre-99 trucks, but it should work on a Super Duty. You can install the heater bypass valve used on other vehicles to bypass the heater core when the a/c is on "max". One for a mid-90's Ranger should work. The valve is teed into the vacuum line controlling the fresh/recirc. door so it only bypasses the heater core when the door is in the recirculating position (max and off).
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old Nov 8, 2002 | 08:02 AM
Deebo's Avatar
Deebo
A/C not cold enough
velocicurtis
2004 - 2008 F150
Jul 17, 2014 10:39 PM
RA31925
All Things Towing
16
Oct 26, 2013 07:59 PM
btroy
1983 - 2012 Ranger & B-Series
Aug 16, 2009 07:02 AM
btroy
Aug 14, 2009 12:31 PM
flybaby_3
Aug 13, 2007 08:21 PM
