blower motor resistor
Old Dec 15, 2002 | 02:58 PM
mathelm's Avatar
mathelm
Yes Steve, thank you. Now you two boys go and have your date. Play nice now, ya hear...
Let the **** burgade carry on...
Old Dec 15, 2002 | 04:47 PM
kioolt's Avatar
kioolt
http://lycos.infoplease.com/ce6/sci/A0841707.html
Old Dec 15, 2002 | 06:24 PM
bumpin_BII's Avatar
bumpin_BII
Old Oct 29, 2007 | 04:25 PM
ericjon652004's Avatar
ericjon652004
2000 f150 6 cylinder.
Took me a while to figure out why my fan just quit blowing one day. My dad fouund this forum. put us on the right track. Thanks.
Old Nov 10, 2007 | 09:39 PM
pdxTreme's Avatar
pdxTreme
I know this thread is 5 years old but I thought I'd just say thanks for all the info. The little spat about rheostats vs. resistors was helpful. Since I didn't know what I was looking for, when I pulled my resistor pack out I was able to immediately recognized for what it was --it's all about the coils. And I even understood why there were only three coils for my 4-position switch (high speed let's all go through) The bottom line on my repairs today was that the resistor pack wasn't the problem --nor the switch. The fuse had blown! Lesson: always start at the beginning.
thanks again
Old Nov 15, 2007 | 08:08 PM
smudge's Avatar
smudge
I have the same problem with my blower ....so when I go to the dealer to buy the new part what does ford call it?
Old Nov 15, 2007 | 08:41 PM
pdxTreme's Avatar
pdxTreme
I'm no expert by any stretch of ones imagination, but according to a lot of web-based research, I think it's just called a "resistor pack" or "blower motor resistor." These appear to be widespread terms used in various car models (not just Ford).
If you Google "Ford Heater Resistor Serial Number" you'll get a number of hits. My strategy was to remove the part and take it in to the dealer --but as I mentioned, all I needed was a 10-cent fuse. (well, make that $3.00!)
I have an '89 F150.
Old Nov 25, 2007 | 07:10 PM
smudge's Avatar
smudge
resistor pack it is.... $32.00 got heat now and happy,thanks for the help.
Old Dec 4, 2007 | 02:28 PM
Briki98's Avatar
Briki98
I have worked at Ford for 14 1/2 years now at the Sheldon Road Plant in Plymouth MI. We are the climate control division of Ford. I have been one of the Final Inspectors for the F Series heater/AC assembly for a number of years now, and we referred to the part as the blower motor resistor. NOT a rheostat. There IS a difference. If the blower runs at high speed only, the resistor is most definitely bad because at high speed the blower bypasses the resistor and runs at full current. This is my first post, but I hopes this helps.
Old Dec 7, 2007 | 06:35 PM
gjohns23's Avatar
gjohns23
Replacing the resistor
Any tricks to removing or reinstalling the resistor? I am driving a 2000 Ranger.
Old Dec 7, 2007 | 06:37 PM
gjohns23's Avatar
gjohns23
Replacing Flower motor resistor
Old Dec 7, 2007 | 08:36 PM
Briki98's Avatar
Briki98
The bad thing is that when I see and test the part, it is not yet in a vehicle. (My plant only makes the climate control systems) I only see the complete air handling unit. I have inspected on the Taurus-Sable, F-series and Expedition-Navigator lines. There are a lot of similarities between parts though. The resistor should be held in with two screws that take a 5/16 socket. I don't know the exact location of the resistor on the Ranger unit. So, offhand I can't tell you where to look for it at on the vehicle. Monday I can talk to somebody on the Ranger line and find out for you. Sorry I can't be of more help right now.
Old Dec 7, 2007 | 08:40 PM
  #28
Briki98's Avatar
Briki98
If I'm not mistaken the resistor on the ranger is to the right of the blower motor inside the engine compartment. I'll double check for you Monday.
Old May 30, 2009 | 12:33 PM
  #29
herchenstroker's Avatar
herchenstroker
Here's my problem: When my blower blows, I have all 4 speeds, but I have intermittent voltage at the blower motor. I first suspected a fuse or relay, but the intermittent thing sort of rules that out. My local Ford dealer says a faulty resistor can cause such a malfunction, so upon this advice, I've found and removed the blower resistor on my 2001 F-350. Any thoughts before I replace a circuit that may or may not need to be replaced?
Old Jun 1, 2009 | 09:15 AM
  #30
Briki98's Avatar
Briki98
The resistor could be the culprit, but with it being intermittent, you might also want to check the wiring harness to see if there might be a broken wire, a bad ground, a bad connection, etc. The intermittent problem could be any of these. At the plant we have TONS of spare parts so we would just swap one thing out for a new one and see if that would be the fix. I know it's not quite that easy and convenient when it's on your own vehicle!
Good luck.
