Sponsored by: Real Truck
Hi, New here.
Old Jun 30, 2008 | 09:05 PM
Fordranchero's Avatar
Fordranchero
Hi, New here.
Just bought a 92 Super Duty F450 from Canadian Department of Defense.
41,000 Kms original, 7.3 lt natural e4od tran, 12,000 lb. Ramsey winch and bumper package on front, huge alternator, zero start fuel heater.
Very clean and well kept except for crunchs on roof from big combat boots adjusting antenaes on roof.
Manual is in french, any tips on use of OD for tranny?
Going to put in full set of gauges as factory on cluster suck.
Old Jul 1, 2008 | 12:08 AM
c.f.moore's Avatar
c.f.moore
You have a 7.3 IDI . It benefits greatly from a turbo addition.
In my '90 7.3 w/E40D, the manual stated that you could tow in OD. Ford changed that recommendation several times over the years. Turn off the OD when towing up grades, or when it starts hunting between OD and Direct. The E40D benefits from regular maintenance.
Good luck
Old Jul 1, 2008 | 08:40 AM
03_PSD's Avatar
03_PSD
welcome to FTE, great place to learn and share.
Old Jul 1, 2008 | 12:29 PM
madjak's Avatar
madjak
Welcome to FTE! Check out the 7.3 forums for more info.
Everyone here is very helpful and willing to share their knowledge.
Old Jul 1, 2008 | 04:51 PM
ryaneverk2's Avatar
ryaneverk2
Welcome to FTE, Fordranchero!
I agree with c.f.moore... when towing, only lock O/D off (by pressing the O/D off button on the end of the shift lever) if the trans starts to shift between drive and overdrive repeatedly. Otherwise, let it pick the gear on its own. You can always lock it off and force it to stay in drive if you want, even if it's not hunting, just to get some higher RPMs (and probably slightly lower EGTs, had it been lugging a bit in O/D).
And as madjak mentioned, be sure to check out the 7.3L PSD section, too.
