EEC Computer removel
Old Jun 30, 2008 | 05:53 PM
tree8588's Avatar
tree8588
To get the computer out, do you pull it out from the engine or cab side of the firewall?
Old Jun 30, 2008 | 06:14 PM
quicklook2's Avatar
quicklook2
92 up from engine compartment.
earler from inside cab.
disconnect battery first.
Old Jun 30, 2008 | 08:20 PM
bluesman2333's Avatar
bluesman2333
Why are you pulling the EEC? If you suspect a bad computer, you will prolly end up replacing something else to fix the problem @ computers rarely go bad.
Old Jul 1, 2008 | 09:13 PM
tree8588's Avatar
tree8588
computer pull
Switched out pretty much everything else already. A friend has a F-150, same year and all, going to switch computers and find out.
Old Jul 1, 2008 | 09:23 PM
quicklook2's Avatar
quicklook2
what is the trucks problem?
Old Jul 3, 2008 | 04:11 PM
jonjanke's Avatar
jonjanke
On my 92 f250 4x4, I loosened the plastic shroud and went in through the left side wheel well. It's easier to get to that way. Then loosen the single bolt that holds on the elec. connector and slide out the computer. It took me about 20 minutes to do this.
hotweekend
Jan 29, 2013 05:48 PM
hotweekend
Jan 29, 2013 07:12 AM
larocquejr
Jun 4, 2012 10:17 PM
2002BLGT
Feb 21, 2008 05:40 PM
water 5
Computer Chips & Tuners
Feb 26, 2006 07:48 PM
