Help, '05 XL down for the count
Old Jul 1, 2008 | 05:05 PM
Keystone.45's Avatar
Keystone.45
That would be great. Someone here sent me the Oasis and all it showed was one oil change.
VIN is 1FTRF12W15NA37534
Thanks!
Old Jul 1, 2008 | 05:19 PM
rob188's Avatar
rob188
18578 2003-2005 Multiple Vehicles - Dtc P0191, P0171 And/or P0174
For 2003-2005 Multiple Vehicle Lines Which Use Electronic Returnless Fuel System {erfs}, The Appearance Of Self Test Continuous Memory Diagnostic Trouble Code P0191 (frp Ckt Performance) Does Not Specifically Indicate A Fuel Rail Pressure Sensor Or Fuel System Circuit Failure. The Fuel Rail Sensor Should Not Be Replaced Based Only Upon The Appearance Of This Dtc Alone. Follow The Revised On-line Pc/ed Pinpoint Testing For Dtc P0191 To Diagnose. Also, The Appearance Of Dtc's P0171 (ho2s11 Lean Prt Thrt) And/or P0174 (ho2s21 Lean Prt Thrt) May Be The Result Of Low Fuel Pressure. Do Not Replace Any Components Or Reprogram The Pcm Unless Pinpoint Testing Or Other Published Service Procedures Specifically Provides That Repair Action.
Old Jul 1, 2008 | 05:27 PM
rob188's Avatar
rob188
ISSUE:
Some 2005 F-150 vehicles built before 1/31/2005 and equipped with the 4.6L engine, may exhibit issues related to throttle pedal response hesitation on tip in, or the malfunction indicator lamp (MIL) on with one or more of the following diagnostic trouble codes (DTCs).
P0172 - SYSTEM TOO RICH (BANK 1)
P0175 - SYSTEM TOO RICH (BANK 2)
P0171 - SYSTEM TOO LEAN (BANK 1)
P0174 - SYSTEM TOO LEAN (BANK 2)
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B35.6 or higher. Calibration files may also be obtained at MOTORCRAFT PARTS FOR FORD, LINCOLN OR MERCURY VEHICLES.
NOTE: THROTTLE PEDAL RESPONSE WITH ELECTRONIC THROTTLE CONTROL (ETC) DIFFERS FROM RESPONSE WITH A THROTTLE CABLE. REPROGRAMMING THE PCM WILL IMPROVE, BUT MAY NOT ELIMINATE, THIS CONDITION.
Old Jul 3, 2008 | 11:47 AM
Keystone.45
Fixed!
Turns out is was MAF sensor.
Old Jul 3, 2008 | 12:08 PM
Fosters's Avatar
Fosters
glad it was something easy was it over-oiled from the k&n?
Old Jul 3, 2008 | 03:11 PM
Keystone.45
I don't think so, but then anything is possible. The K&N was on there for about 3 months and 3K miles and even though the sensor was clean and dry it was still apparently giving the PCM some very erroneous data. I understand people can over oil the filters when cleaning them, but I've had a C&L and more recently a Steeda (since going FI) on my Mustang for several years now and haven't had a single problem. I'm told the replacement sensor has a lifetime warranty, so I'll put the K&N back on and see what happens.
Thanks to everyone for the input.
AJUSAcom
Vendor Specials, Discounts, Product Announcements & Group Buys
Mar 31, 2012 03:31 PM
weyland426
6.4L Power Stroke Diesel
Nov 4, 2007 06:15 PM
tonum24
29
Sep 6, 2004 11:46 AM
Alton Ray
Jan 25, 2004 09:28 AM
mikea
1997 - 2003 F150
Jan 4, 2004 05:19 PM
