Vacuum Lines
Old Jun 27, 2008 | 09:13 PM
Tonka 68's Avatar
Tonka 68
Unhappy Vacuum Lines
Hey hows it going guys I have a question about vacuum lines I've been a Ford man since the 70's and worked on them for yrs but I bought a 71 F 100
3 yrs ago and the time came to put a good used motor in until I get more $$$$ to finish turning the original 5.0 into a stroker and I started looking closer and found most of the lines missing so I need input on a Diagram.
I have the full 5 vol set of shop manuals from 1971 but it helps only so much.
So any help would be great.
Old Jun 28, 2008 | 06:30 AM
Freightrain's Avatar
Freightrain
Vacuum lines on a 71? Well, maybe three of them: vacuum advance on dizzy, possible power brakes and PVC on valve cover. That about covers it I think.
The only other hoses would be heater hoses.
If the motor you installed came from something newer and has MORE vacuum tees, then it usually is just Emission stuff and these trucks don't have any.
Old Jun 28, 2008 | 06:27 PM
Tonka 68's Avatar
Tonka 68
I have some of the stuff for the C 4 and some is missing other wise I have Dizzy advance and retard,and the C 4 and the PCV but after looking in the Factory manuals for this baby I realized half the things for tranny vac are missing and I'm not putting any of the puke back on but this is to hold me until I'm done with my other 302
a 30 over stroker with 4340 steel crank,4340 H beam rods,custom ground cam, Twisted
wedge race heads and a high rise tunnel ram with duel 550 edelbrock carbs so this is only a hold me over but I want it right.
Old Jun 29, 2008 | 06:40 AM
Freightrain
Ya, did forget to mention the vacuum modulator line for auto tranny(I don't have any auto trucks). It goes in the back of intake where power brake would hook up to.
Old Jun 29, 2008 | 01:57 PM
Tonka 68's Avatar
Tonka 68
thanks for your input it's just that things are not the way they should be under the hood and you can say a good cleaning is going on now.
f150country
Feb 10, 2017 01:20 PM
96f150
1997 - 2003 F150
Nov 2, 2016 06:46 PM
rugster1
Dec 10, 2015 08:23 AM
rugster1
Dec 7, 2015 07:52 AM
busmonky
Jan 16, 2009 04:34 PM
